Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 04-03-2001, 11:33 AM   #21 (permalink)
Alan
Posts: n/a
Re: inclimometer
: This is a cheap item that I ran across<br>: www.jcwhitney.com/product.jhtml?CATID=4567<p>The Mitsubishi inclinometer is a self contained unit. It would be easy to transplant into a G. One thing to<br>note is that they were prone to leakage. They are filled with mineral oil (baby oil). Mine leaked and I have now fixed it. The fix is to coat the back (the part that flexes with atmospheric pressure changes) with a generous coat of silicone rubber. The fix is much easier if you do it the diaphram leaks.<p>...Alan<br><p>
Old 04-22-2001, 04:59 PM   #22 (permalink)
Andy Mustoe
Posts: n/a
Re: inclimometer
Glen<br>You mention ORC of Germany for an incinometer But have you got the web address as I couldn't find them on a web search so if anyone has the web address for them I would apreciate it.<br>Andy<br>: Dear Brent I have seen a good inclinometer in the ORC catalogue of germany look them up on the web . They have a really good online catalogue.Hope this helps Glenn<p><br><p>
Old 04-22-2001, 06:38 PM   #23 (permalink)
Pete
Posts: n/a
Re: inclimometer (Webpage)
: Glen<br>: You mention ORC of Germany for an incinometer But have you got the web address as I couldn't find them on a web search so if anyone has the web address for them I would apreciate it.<br>: Andy<br>: : Dear Brent I have seen a good inclinometer in the ORC catalogue of germany look them up on the web . They have a really good online catalogue.Hope this helps Glenn<p>I think this is what you are looking for. http://www.orc.de/<br>Good Luck<br><p>
Old 01-04-2005, 02:55 PM   #24 (permalink)
4x4rancher's Avatar
Date registered: Jan 2004
Vehicle: 230 G BGS 300G TDI
RE: inclimometer
I have fitted a inclinometer/g meter in my 300 gd and 280 ge both are fitted with spacers and therefore have a lower c of g.
The 280 has frequently taversed side slopes of 50deg of angle, I beleave the book figures ere on the side of caution.
I will down load a pic of the instrument I use in the next day or so, a simple method just to mesure is make a plumb bob and stick it to the roof lining with blue tac, then go out and have fun, but gentley.
4x4 Rancher
300D Turbo Intercooled
4x4rancher is offline   Reply With Quote
Old 01-04-2005, 05:10 PM   #25 (permalink)
Captain Spalding's Avatar
Date registered: Apr 2003
Vehicle: 300GE Cab, 6.9
RE: inclimometer
I really like the Mitsubishi version, as it displays pitch and roll in one aircraft-style instrument. The Toyota version has separate gauges for each. Also it features a silhouette of the Toyota [:(]
An issue with either of these is that they are engineered to work in a given vehicle, and when mounted in a different vehicle there must be some means of initial calibration for the pitch. I was thinking of replacing my voltmeter with the Mitsu version. Assuming there is room behind the dash, I would have to install it with the truck sitting on a level surface and use shims so that it reads level correctly.
I have purchased one on e-bay ($10 [:)]) but have yet to insall it. I was able to purchase it without the instrument pod and additional gauges.
Captain Spalding is offline   Reply With Quote
Old 01-04-2005, 05:41 PM   #26 (permalink)
AlanMcR's Avatar
Vehicle: 96 G300DT
RE: inclimometer
The Mitsubishi instrument is pretty nice. The only downside is that they leak. The leak comes from atmospheric pressure flexing the back membrane. I don't think that Mitsubishi tested it by driving it up to 7000' and back a hundred times. You can add a ~3mm layer of silicone seal across the back of it before it leaks (not afterwards). It is difficult to seal once the oil gets all over everything.
Now you got me thinking. It was always a good conversation piece[:D].
...Alan
63 230SL
96 G300DT
98 E300DT
AlanMcR is offline   Reply With Quote
Old 01-04-2005, 05:51 PM   #27 (permalink)
GwagenLover's Avatar
Vehicle: 02 G500 & 05 ML350
Benz world post on angles
I knew I had a picture of the angles somewhere. I found it and hope the picture uploads ok.[;)]
Visit my website: www.oldsalemhomes.com and see what it is like living in a histoic town
GwagenLover is offline   Reply With Quote
Old 01-04-2005, 08:51 PM   #28 (permalink)
RE: inclimometer
AlanMcR - 1/4/2005 4:41 PM
No doubt you're right about the leak issue. The one that was shipped to me was dry, and the E-Bay seller said that when he shipped it, it was full. Perhaps it took a plane ride to get to me and the altitude forced it to leak.
I've made a half-hearted effort to find a more robust substitute. Perhaps an instrument intended for ultralight aircraft.
If I may ask, how was the Mitsu gauge you are referring to mounted? In dash? Dashtop pod?
Old 01-05-2005, 12:51 AM   #29 (permalink)
4x4abc's Avatar
Vehicle: TJ, FJ40, JGC, 280GE, G500
RE: inclimometer
4x4rancher,
If you show me how you drive on a 50 degree side angle I'll buy you a beer - in fact I'll buy you beer for life.
Harald
4x4abc is offline   Reply With Quote
Old 01-05-2005, 01:27 AM   #30 (permalink)
Johann's Avatar
Vehicle: 81 240GD 99 290GDT
RE: inclimometer
Here is a G doing a 45 degree side slope. At 45 you are able to lift the wheels when pushing the car but it can still go a bit before it starts feeling unstable.
This one is me at about 38 degrees. Can't lift the wheels by pushing.
At these angles you have to drive extremely slow and is a good thing to have somebody spotting you on the up side to prevent roll-over.
I think 50 degrees will be a very BAD idea.
Johann is offline   Reply With Quote
