» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 02-06-2001, 05:32 AM   #1 (permalink)
Frederic PALLUY
Posts: n/a
Kit turbo & 300 GD
I had seen an old message cocnerning a turbo kit that can be used on a 300gd. I'd like to know <br>1) if it is easy to adapt ;<br>1) where to find it ;<br>3) how much does it cost...<p>Thanks<p>Fred<br><p>
Old 02-06-2001, 06:36 AM   #2 (permalink)
mike
Posts: n/a
Re: Kit turbo & 300 GD
Fred,<p>This is made by a company in the UK, and it's a supercharger, not a turbo. They have a web site.<p>http://www.tdi-plc.com/Merc300GEclass.html<p>Seems like a great deal if you already have a 300GE, especially the one that bolts on and off easy.<p>Mercedes 300GE<br>stock 170hp@5500-255Nm@4250<br>supercharged 265hp@5500-385Nm@4250<p><br>cheers, <p>Mike<br><br><p>
Old 02-06-2001, 09:29 PM   #3 (permalink)
frank
Posts: n/a
Hi Fred,<p>for the "old" 300 GD with OM 617 there is two different kits:<p>1. STT Svenska Turbo Technic - they have a dealer/workshop network throughout the world. An expert retro fit when applied correctly.<p>2. The original OM 617 A which uses the same basics as the 617 but has extensive modifications to it (pressurised oil-cooling for the pistons, sodium filled valves and a few "minor" bits and pieces. The 617 A was never availbale ex works in the G, retaining full offrod-ability of the the G is therefore a task for an expert (only a handful in the world) when converting ! <p>The same goes for the OM 603 in the "newer" G´s. <p>It is never a good idea to fit a turbo-kit to an older engine. Also keep in mind, that the 711.2 gearbox of the G will not cope with the extra torque, only the 711.1 oder the Getrag gearbox can. <p>Best of luck - frank<br><p>
Old 02-09-2001, 12:20 PM   #4 (permalink)
glenn parker
Posts: n/a
: I had seen an old message cocnerning a turbo kit that can be used on a 300gd. I'd like to know <br>: 1) if it is easy to adapt ;<br>: 1) where to find it ;<br>: 3) how much does it cost...<p>: Thanks<p>: Fred<br>dear fred I have fitted a turbo kit to my 300 gd the difference to the performance is incredible! Fitting the kit is easier on some models than others.460s are easier than 463s but you must have good technical skills ,fabrication skills ,equipment,nerve and patience.The best kit is STT in sweden and you need to speak to Glenn Berglund at glenn.berglund@stt.se STT say you can fit in 3 days but it took me 2 weeks.<br>The cost was 26000 swedish krona plus vat for my 463 model cheaper i think for 460.Was it worth it absolutely! I cannot describe the difference only by saying it is a totally different vehicle and actually accelerates yet the fuel consumption has hardly altered<br>Although the kit is not cheap it is superb quality and looks like oem equipment hope this helps.Remember if you want to go you have got to blow .TURBO DIESELS RULE OK.<br><br><p>
