How much wind noise is too much? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 05-22-2010, 06:22 PM   #1 (permalink)
Date registered: May 2010
When I drive on the freeway (60+ mph) in my '02 G500 it almost sounds like the driver side passenger door is open. There is a buffeting sound right behind me.
The gaps in the doors are the same as on the rest of the truck. The door is not loose in anyway. All the weather stripping seems to be in order so I cannot really figure out what the problem is. Maybe I am missing some sound insulation?
I know the car has the aerodynamic qualities of a brick wall but this is not normal right? Any suggestions on what I can do to fix this?
Doyen is offline   Reply With Quote
Old 05-22-2010, 09:49 PM   #2 (permalink)
Texas G's Avatar
Date registered: Jan 2007
Vehicle: 2003 G500
Is the sunroof open but all the windows are up? (I'm not trying to be funny.) When I drive my G with all the windows up and open the sunroof all the way (not just the tilt/vent), there are definitely wind/buffeting issues, so I just crack open the rear windows a little bit, and all is well.
Texas G is offline   Reply With Quote
Old 05-22-2010, 10:44 PM   #3 (permalink)
The car would have filled up with water by now if any of the windows/sunroof was open...I will double check tomorrow.
Old 05-23-2010, 09:17 PM   #4 (permalink)
AlanMcR's Avatar
Vehicle: 96 G300DT
Well the sunroof could still be the problem. If you leave the sunroof in the pop-up position for long periods of time the front rubber gasket can get compressed and allow quite a bit of noise in. A strip of duct tape over the sunroof gaps will rule that problem in/out.
...Alan
63 230SL
96 G300DT
98 E300DT
AlanMcR is offline   Reply With Quote
Old 05-23-2010, 10:25 PM   #5 (permalink)
Interesting...I will try that. My sunroof has a dent in it...it functions perfectly though.
Old 05-25-2010, 08:23 PM   #6 (permalink)
JohnBrukiewicz's Avatar
Date registered: Jan 2010
I usually only drive my G several times a month and the remainder of the time the vehicle is garaged. I always left the sunroof cracked in the upward position to allow the vehicle to ventillate for the weeks it sits idle.
Some time ago I had a similar issue and turns out it was the gasket near the front of the sunroof from the steel plate pressing down against the gasket. I left the sunroof down for a couple of weeks and the next time I drove the vehicle the issue had gone away.
Seeing as you have a dent in your sunroof I am nearly positive you have an area near the front which is skewed from its original position causing air to be pushed downward into the vehicle.
Geländewagen w463
JohnBrukiewicz is offline   Reply With Quote
Bookmarks
Wind Deflector, Wind Screen, Wind Stop, or Wind Schott for R129? masaki@japan R129 SL Class 4 11-20-2008 09:43 AM
Rear end noise when break after starting/cold; wind noise from driver side window. zhuorongdeng W203 C-Class 1 07-03-2007 01:59 PM
Wind Noise Sako83 W124 E,CE,D,TD Class 0 06-01-2004 10:46 AM
"Squealing noise", and high pitched wind noise.... JKRD101 W215 CL Class 0 01-01-2004 02:36 PM
wind noise Chuck G-Class 7 03-08-2002 04:36 PM
