» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 11-06-2009, 03:39 AM   #1 (permalink)
Reinier's Avatar
Date registered: Nov 2009
Vehicle: W460 / Puch 280GE
Wheel sizes '84 280GE
On my restau 'G' project , i've discoverd a slight problem with the wheels, the distance between te steering ball joint and the inside of the rim, is less than 2 millimeter... these wheels were mounted on the car when it was bought.
On the inside of both front wheels, (picture) the outside edge is damaged, probably due to dirt and other stuff wich jammed itself in between the linkage and the rim.
So i figure that these wheel's are no good. perhaps w463 modells?
Scrolling down the collection of wheels there are several ET value's... with and without the use of spacers.
Can someone tell me what kind of wheels i should buy (what size) for use without spacers, and enough clearance at the steering hub?
Thnx!!!
Reinier.
Reinier is offline   Reply With Quote
Old 11-06-2009, 02:27 PM   #2 (permalink)
Date registered: Jun 2009
You MUST use spacers of 25mm minimum with that wheels.
Mercedes-Benz Gelaendewagen G 460, 461, 463 stock and custom wheels, bolts and center caps, all specifications. Felgen und Radschrauben fuer G-Klasse with 5/130 bolt pattern
Yor wheels are the number 6
Firebird89 is offline   Reply With Quote
Wheel sizes? HITWTOM W123 E,CE,D,CD,TD,TE Class 8 09-30-2007 08:31 PM
Max tire sizes for '86 280GE jbotthoff G-Class 2 10-20-2005 07:41 AM
Wheel sizes...help. AlanS The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 12-07-2004 04:04 PM
Wheel sizes? ellisbailey R170 SLK Class 9 08-17-2004 02:17 PM
1984 280GE Tire sizes Rabih G-Class 5 04-02-2002 09:39 PM
