» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 07-01-2009, 10:38 PM   #1 (permalink)
Date registered: Jan 2009
Vehicle: 2000 G500
Additional Horn
I was looking to add a horn to my G, and there are some different options. I could set it up as a whole different system, and have it controlled by a separate button or switch, or I could wire it into the existing horn setup, and have a switch to select between the two.
If I take the whole different setup approach, then where should I route the wires through the firewall? Is there an existing hole? Or would I have to drill another hole?
If I wired it into the existing setup, then how should that be done?
rgoode is offline   Reply With Quote
Old 07-02-2009, 02:27 PM   #2 (permalink)
AlanMcR's Avatar
Vehicle: 96 G300DT
Hook your new horn(s) up to the old horn wires. There is already relay that should handle a lot of current. Search the fuse list to see what the system is rated for.
...Alan
63 230SL
96 G300DT
98 E300DT
AlanMcR is offline   Reply With Quote
Old 07-02-2009, 09:47 PM   #3 (permalink)
Vehicle: 2000 G500
I thought about doing that, but I would like to keep the existing horn because the new horn is one of those horns that sound like the Model T. I do not want it as my primary horn.
2000 G500 with 285/65R18 BFG All Terrain ko's
Old 07-03-2009, 08:33 PM   #4 (permalink)
Andyman746's Avatar
Date registered: Jan 2008
Vehicle: W463 G500
Great thread. I don't mean to thread jack but what horns are compatible "plug and play" to the stocks?
Andyman746 is offline   Reply With Quote
Old 07-03-2009, 10:37 PM   #5 (permalink)
fernweh's Avatar
Date registered: Mar 2004
Vehicle: 91 300GE, W 200
Model T sounding horn? I thought it would be the "River Kwai" or "Aida's March" theme or at least a decent Mexican earworm to be played......
If you can decide which one to play when, with a help of a DPDT relay you could wire it up in a way, that without the lights on (fog lights maybe) the standard horn is sounded and in a different mode or mood the annoying one is activated when the (chosen) light is switched on.
No need to penetrate the fire wall or to mount a non OEM switch in a finer Mercedes-Benz dash.
fernweh is offline   Reply With Quote
Old 07-12-2009, 12:32 AM   #6 (permalink)
Pack's Avatar
Date registered: Jun 2006
Vehicle: 2002 E430 Special Edition; 2005 E500 4matic Wagon; 1999 (Europa) G500; 1991 560 SEL
Send a message via Yahoo to Pack
Totally off-topic, and I apologize for that, but I've been thinking about an auxilliary horn as well.
Would there be any way to acquire and hook up the monstrously loud horn that was on the old 600 "Grosser" limousines?
Europa Geländewagen - takes "unlike any other" to another level.
Pack is offline   Reply With Quote
Horn stop working, where is the fuse for the horn njstreeter W203 C-Class 1 09-09-2008 10:53 AM
Additional Additional Photos from Hawaii Northbenz R171 SLK Class 3 02-25-2006 04:52 AM
Additional Lighting ??? Bora20 G-Class 3 03-08-2004 12:22 AM
Is there a "horn mod"? My horn seems a bit soft and more of a beep than a HONK. Thanks. J-bird W163 M-Class 36 12-02-2003 09:40 PM
