» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 10-13-2008, 05:32 PM   #1 (permalink)
Date registered: Jul 2006
Aux, Front Fog, Rear Fog Lights Wiring
I am having my Roof rack fabricated as we speak out of the same Stainless Steel bar that is used on the AMG rear Light Grills. The railing around the rack will be the same height as the Light Grills as well. Along the sides and the rear of the rack, I am having mounts welded on to accomidate 2 rectangle work lights off the rear, and 2 off each side. Also Im having a mount made in the front middle to accomidate a remote controlled spot light. I just ordered 2 Hella 1000 7" round fog lights for the front grill as well.
I always drive with my truck with both sets of lights on, headlights and bumper mounted fog lights. So I was considering wiring the bumper mounted headlights to a relay that get activated with the headlights. Then use the fog light position in the switch for the new brush guard mounted fog lights and also hook up the rear fog light with a relay to that circuit since it is appropriate for both sets to be on at the same time. Then use the Rear Fog light position in the switch to control a relay for rack mounted work lights.
Anyone have any insight against this wiring idea?
I dont want to add any switches to the vehicle and this seems to make perfect sense in how to use all the switch circuits.
MKappeli is offline   Reply With Quote
Old 10-13-2008, 11:43 PM   #2 (permalink)
ZĂ© Bocaina's Avatar
Date registered: May 2005
Vehicle: G 500 06 / 300 GE Cab 91 / 300D 83 Turbo/ 300GD 1980
What is your truck model?
ZĂ© Bocaina is offline   Reply With Quote
Old 10-15-2008, 11:45 AM   #3 (permalink)
2004 G500
Old 10-20-2008, 05:07 PM   #4 (permalink)
ewalberg's Avatar
Date registered: Jul 2003
Vehicle: 00 g500
Just a note regarding use of Fog lights at all times... i ran across this on Daniel Sterns lighting website while looking up some other stuff. He would argue your selling yourself short by running with your fogs on.
Daniel Stern Lighting Consultancy and Supply
In clear conditions, more foreground light is not a good thing, it's a bad thing. Some foreground light is necessary so you can use your peripheral vision to see where you are relative to the road edges, the lane markings and that pothole 10 feet in front of your left wheels. But foreground light is far less safety-critical than light cast well down the road into the distance, because at any significant speed (much above 30 mph), what's in the foreground is too close for you to do much about. If you increase the foreground light, your pupils react to the bright, wide pool of light by constricting, which in turn substantially reduces your distance vision—especially since there's no increase in down-the-road distance light to go along with the increased foreground light. It's insidious, because high levels of foreground light give the illusion, the subjective impression, of comfort and security and "good lighting".
<img src="http://">
ewalberg is offline   Reply With Quote
Wiring for Aux fog lights (bumper mount) bikerider58 W163 M-Class 2 11-02-2005 08:37 PM
ML55 fog lights & ML Sport Package fog lights angldrkns9 W163 M-Class 0 10-27-2003 07:12 AM
FS: 2003 SL500R Body Kit (NON Sport) Front, Rear Aprons, Side Skirts, fog lights...Brilliant Silver RezaH R230 SL Class 0 11-11-2002 09:42 PM
Aux Fog & Rear light switch questions jamsong W163 M-Class 17 02-16-2002 08:48 AM
Aux and Fog lights on the ML Blau. W163 M-Class 3 05-29-2001 03:08 PM
