I'm trying to replace the center air vents in my 03 G500. Does anyone have a diagram showing how to remove and install this part? The parts diagram is not helpful. Would appreciate it!
From an initial look @ the WIS, the steps to remove are to remove the differential lock switches, partially remove the center instrument cluster cover until the bolts are accessible (leaving electrical connectors in place), remove 2 screws, and pull the vent out and up. All the while risking damage to clips, wood trim, etc.
Looks like a PITA in my opinion. Here are some screen caps from the WIS search for 'ceter vent' doc (AR68.10-P-1150GM is what it came up with) (mine is a 463.246, and it pulls up is the same doc number, so the newer DVD nav picture shouldn't throw it off much)
