Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 03-23-2008, 01:56 PM   #11 (permalink)
ZĂ© Bocaina's Avatar
Date registered: May 2005
Vehicle: G 500 06 / 300 GE Cab 91 / 300D 83 Turbo
Originally Posted by Ted baldwin View Post
..........I got the me suggesting that I post also in a nother forum. I have done so. waiting for someoe to answer.
Ted
Please complete your mail !
ZĂ© Bocaina is offline   Reply With Quote
Old 03-23-2008, 01:58 PM   #12 (permalink)
Date registered: Jun 2003
Vehicle: 2000 G300 TD
Did you get my second pm?
GWOA Administrator
G-Wagen Owner's Association
http://www.gwoa.co.uk
Maxwell Smart is offline   Reply With Quote
Old 03-23-2008, 02:01 PM   #13 (permalink)
Zé Bocaina - Ted has a late model G55K. I think the fuses may be different to a 2003 G500.... but should be the same as your 2006 G500.
Old 03-23-2008, 02:24 PM   #14 (permalink)
Originally Posted by Maxwell Smart View Post
ZĂ© Bocaina - Ted has a late model G55K. I think the fuses may be different to a 2003 G500.... but should be the same as your 2006 G500.
owners manual doesnt say nothing and so EPC. Loocking at the workshop manual the 13 position is for the Pressure pump fuse - terminal 15 - 20 AMP , situated at the rear position , right side of central console.There is another fuse of 20 AMP for the pressure pump on position 19 of same rear fuse box - terminal 30.
Fernando
Old 03-23-2008, 02:26 PM   #15 (permalink)
Date registered: Dec 2003
Originally Posted by ZĂ© Bocaina View Post
I recomend you Mr. Harald cd about G500 where you will find all material you need about G 500 until 2003 . I dont know if the CD has been renewed.
Harald is member of our forum with nick : 4x4abc
PM him !
regards
Fernando
.............Thanks for the suggestion but you posses the answer that I need. Just look at your own fuse chart and tell me what fuse 13 does. Please! Mine is a 2005. Not 2003.
Ted
2003G55
Ted baldwin is offline   Reply With Quote
Old 03-23-2008, 02:29 PM   #16 (permalink)
..............Thanks!!!!!!!!!!!!!!!!!!!!!!!
Ted
Old 03-24-2008, 08:37 AM   #17 (permalink)
Date registered: Nov 2005
Since this is already started on the fuse topic....
My front two side lamps (the yellow ones) aren't working and i traced it to the fuse that says "elektronic". I'm figuring this something different than just a fuse... Any help guys where to source whatever this electronic module is? Is it a flasher relay or something? Thanks
4tuneit1 is offline   Reply With Quote
Old 07-05-2008, 10:36 AM   #18 (permalink)
NX7R's Avatar
Date registered: Nov 2006
Vehicle: 2002 Mercedes Gelandewagen G500 Brilliant Silver.
Post 2002 W463 G500 Fuse list. 2 pages
I need to know the what fuse controls what. I have lost my list. I have searched but did not find the answer. There have been references to it, but no information. Does anyone have a list of fuse number and what that fuse number controls? I am specifically looking for the fuses for the high beam lights and driver side heated seats both back and the bottom. I know where each fuse number is located but not what it does. This is for a 2005 W463.
Thanks.
Ted
Here is the list....I Know it's Late But....Hope it helps...Terry.
File Type: jpg W463 G500 Fuse list page 1.jpg smallest.jpg (61.6 KB, 11 views)
File Type: jpg W463 G500 Fuse list page 2.jpg smallest.jpg (68.3 KB, 6 views)
Terry Gillard
"NX7R"
Las Vegas Nevada, U.S.A.
02 G500 Brilliant Silver.
NX7R is offline   Reply With Quote
Old 07-07-2008, 04:54 PM   #19 (permalink)
fernweh's Avatar
Date registered: Mar 2004
Vehicle: 91 300GE, W 200
The sidemarker lights are controlled by a computer control module, I believe it is the front SAM.....
It is monitoring the functions of you lights and will display an error message in the dash display to let you know if something is not working, burned out or so.
Check the cable connections (behind the headlights) and or the small bulbs - most likely you are not able to check for +12V as the computer turns the circuit off if not correct.
With the help of the Mercedes Star Diagnostics system you can test each separate light bulb for the correct function.
I'm powering a remote located GPS receiver from one of the sidemarker lights and "HAL" knows that too.......
Karl
fernweh is offline   Reply With Quote
2003 G500 Fuse List fastneutron G-Class 2 02-05-2007 10:17 PM
Fuse scheme 300GD w463 -91 gwagen_280 G-Class 3 01-22-2007 12:00 AM
Fuse Box List StinkyMcTinker W116 S, SE, SEL, SD Class 4 08-27-2005 01:43 PM
fuse list in english Guest (MBNZ) General Mercedes-Benz 1 04-19-2001 11:57 AM
fuse list in english Guest (MBNZ) R/C107 SL/SLC Class 1 04-19-2001 11:57 AM
