Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 03-24-2006, 07:13 AM   #1 (permalink)
Date registered: May 2005
463 v 460 off road
Can anyone suggest why the 463 is generally regarded as being clearly superior to the 460 off road? At the G Center in Holland, one of the top G garages in Europe, the then co-owner assured me the 463 performed better. Apparently having an open center diff is an advantage sometimes. Also Total Off Road Magazine in the UK expressed the same view that 463's are much better off road than their 460 ancetors. Why should this be??
Zoltan is offline   Reply With Quote
Old 03-24-2006, 08:16 AM   #2 (permalink)
4x4rancher's Avatar
Date registered: Jan 2004
Vehicle: 230 G BGS 300G TDI
RE: 463 v 460 off road
Zoltan - 3/24/2006 2:13 PM
Not everyone, if any one would agree with either of those sentiments.
4x4 Rancher
300D Turbo Intercooled
4x4rancher is offline   Reply With Quote
Old 03-24-2006, 08:23 AM   #3 (permalink)
I take your point. I own a 460 myself, but it is something I have heard many times. Personally, with all the electrics, and the option to lock the front and rear diffs in any order, I would far prefer to take a 460 in the rough. But the G garage guys off roaded regularly in competitions and they had a huge choice of G's and they were clear the 463 was better. Weird.
Old 03-24-2006, 08:51 AM   #4 (permalink)
UG
UG's Avatar
Date registered: Jan 2003
Vehicle: 83 GD300
I don't know 463's very well, but as far as I know the full-time 4wd is the biggest technical change.
The ability to have open diff in center is an advantage when having to make tight turns. The car turns much better. In (trial) competition reversing or stopping usually carries penalty points, so if you are calculating points, it does matter. Now, if you can reverse a few times to clear a tight corner, then it doesn't matter which you have.
The only downside (that I know of) with 463 is the plastics hanging in the front and back (the bumbers). If you are running competition (seriously), you will need to modify those anyway, so for competition it doesn't matter.
-UG-
UG is offline   Reply With Quote
Old 03-24-2006, 08:55 AM   #5 (permalink)
Thanks for this UG,
As these guys were doing competitions your point about better 463 turning ability in 4wd makes perfect sense.
Thanks.
Zoltan
Old 03-24-2006, 10:42 AM   #6 (permalink)
saigonsmuggler's Avatar
Date registered: Apr 2004
Vehicle: 2004 MB G500 Black
Doesn't the 463 have more engine power too?? This could help in off-road racing competition.
Thai
2004 Mercedes G500 "Offroad Limited Edition"
2005 Toyota Corolla LE (daily driver)
2006 Toyota Highlander 2wd (wife's ride)
Off-roading Videos of My G
saigonsmuggler is offline   Reply With Quote
Old 03-24-2006, 01:12 PM   #7 (permalink)
TH
TH's Avatar
Vehicle: G 500
UG - 3/24/2006 4:51 PM
-UG-
You got it.
And for daily drive, the much lower noise.
<img src="http://img408.imageshack.us/img408/6130/topwinkpg0bq1.gif">
<img src="http://img253.imageshack.us/img253/3883/0071fw1.jpg">
http://www.benzworld.org/gallery/sho...032&ppuser=873
TH is offline   Reply With Quote
Old 03-24-2006, 05:15 PM   #8 (permalink)
Scottgs's Avatar
Date registered: Oct 2005
Vehicle: G500 U1100 C240-4M
I'll second the thought that full-time is the reason. A pretty big step forward, especially when combined with a viscous center diff. [}:)]
Garret
Scottgs is offline   Reply With Quote
Old 03-24-2006, 06:33 PM   #9 (permalink)
Captain Spalding's Avatar
Date registered: Apr 2003
Vehicle: 300GE Cab, 6.9
I've got 2ΒΆ to spare. Having had both concurrently, I can say that each has its strengths.
It can be argued that the simpler diff-lock system of the 460 is more robust and less apt to leave you in a lurch.
The tighter turning circle of the 463 is a major convenience.
The absence of carpet makes the 460 much easier to "rehab" after an outing. A thorough wipe-down with a wet sponge is all it takes to make the interior look great again. With the 463, it takes a little more work.
FWIW, once I got my 463, the 460 rarely saw dirt. That comparison is a little bit apples-to-oranges, though, because the 463 is a SWB - just plain more fun to drive.
Cheers,
Spalding
Captain Spalding is offline   Reply With Quote
Old 03-24-2006, 06:51 PM   #10 (permalink)
ewalberg's Avatar
Date registered: Jul 2003
Vehicle: 00 g500
i think the only real distinction that could be drawn between them based on the statement at hand is that it's because there is a tighter turning circle in a 463 and becuase it has full time 4 wheel drive. The shorter overhang of the 460 bumpers however lend themselves some benefit, which is real because we've seen a number of damaged 463 bumpers here.
For me the value in full time 4wd is in high speed slippery driving where you specifically want unlocked differentials to minimize wheel slip and for more balanced engine breaking.
The rest is a little unrelated becuase the statement doesn't include things like reliability, creature comforts, or on the fly serviceability... it is a statement which more or less assumes all other things being equal (which we know isn't really the case).
<img src="http://">
ewalberg is offline   Reply With Quote
