Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 03-22-2006, 02:18 PM   #1 (permalink)
Kuzuki's Avatar
Date registered: Jul 2003
Vehicle: 1986 280 GE lwb
Send a message via ICQ to Kuzuki Send a message via MSN to Kuzuki
Trailer Plug part number
Hi guys,
did a search but did no find a definite answer. I need a part number for the twin male plug in the atached picture. Is this a DC, Hella or Bosch part?? Hopefully I'll be able te get it localy or on my trip to Germany in may.
Thx
Mike
280GE
Kuzuki is offline   Reply With Quote
Old 03-22-2006, 02:41 PM   #2 (permalink)
Steve D's Avatar
Date registered: Oct 2002
Vehicle: 1984 280GE Cabrio
RE: Trailer Plug part number
I bought one from Sean at Eurotrucks a couple of months ago.
Steve D is offline   Reply With Quote
Old 03-23-2006, 01:20 PM   #3 (permalink)
Date registered: Nov 2005
Vehicle: 280 ge and 300gd
The small rubber plugs are fitted into vehicle wiring sockets so you have a male and female end.
The trailer socket you are best obtaining locally to suit your towed trailer and adapting the wiring accordingley.
The standard socket used is the one common to the E.U. and is cheaply available along with plugs from many makers but allways using the same wire i.d. numbers.
There are two versions so be carefull one with the basics for caravans/trailers for legal lighting and a second version often grey in colour which is to be found powering caravan batteries and accessories, dont mix as damage will occour. Count the pins and male/female configuration.
remember that you will need the warning buzzer and the spec for your (local country) set up.
The plugs either plastic or metal are best being stuffed with grease after testing it may be messy but better than not working.
Dave
David
gwagoncar is offline   Reply With Quote
Old 03-23-2006, 07:54 PM   #4 (permalink)
Kuzuki's Avatar
I'm going to use a 7 pin Bosch socket and plug wich I purchased at a local auto store for $20.
What I have in my G are 2 female end plugs. Since the male plugs are available it would be nice to get them and not to splice into the harness.
I've seen them in the EPC but it wont give a part number.
Thanks and Rgds
Old 03-23-2006, 10:37 PM   #5 (permalink)
EuroTruck's Avatar
Date registered: Sep 2002
A 460 540 1308 up to chassis number 055992.
If your chassis is higher, post up the number and we'll find the right one for you.
-Sean P.
EuroTruck is offline   Reply With Quote
Old 03-24-2006, 09:02 AM   #6 (permalink)
Kuzuki's Avatar
Sean,
send you a PM.
thx
Mike
Old 03-24-2006, 10:25 PM   #7 (permalink)
Bill K's Avatar
Vehicle: 1984 230GE SWB, 2001 CLK 200K CAB
Are these the ones you are looking for`?
#1 pic $3,#2 pic $10.50,#3 pic $3,#4 pic $30.
Bill K is offline   Reply With Quote
Old 10-09-2006, 12:50 PM   #8 (permalink)
keychi's Avatar
Vehicle: g500,g500cabriolet
iam looking for these were can they be bought
louis
keychi is offline   Reply With Quote
