Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 12-13-2005, 08:11 PM   #1 (permalink)
Date registered: Jul 2005
Vehicle: 300gd
Send a message via AIM to bglazen
1983 300gd - automatic some mechanical questions
cna anyone answer some questions
1. I changed the thermostat, and put it in right,,,but the temperatrue gauge rises pretty drasticaly in the red still..maybe the gauge, but i feel its not for some reason
2. smokes a lot when cold...more than i would expect...anything i can do about that?
bglazen is offline   Reply With Quote
Old 12-13-2005, 08:28 PM   #2 (permalink)
4x4abc's Avatar
Vehicle: TJ, FJ40, JGC, 280GE, G500
RE: 1983 300gd - automatic some mechanical questions
leave your radiator cap off, fill to top, start when cold, watch for bubbles rising
If you see bubbles - blown head gasket.
harald
4x4abc is offline   Reply With Quote
Old 12-14-2005, 08:40 AM   #3 (permalink)
Hipine's Avatar
Date registered: Nov 2002
Vehicle: 1980 LWB 280GE
1- can always remove t-stat entirely and see if temp still rises. Don't give much credence to what you "feel". Just check it. Especially easy things like the temp gauge. While you're watching for bubbles, put a thermometer in the water and watch it's temp too to verify gauge reading.
Smoking when cold can be a lot of things. I'd better let one of the "old pros" with 300GDs pipe in here. But it would help to know what the definition of "cold" is. I take it you mean it smokes after starting with no preheat (like electric plug-in or diesel fired heater) i.e. - engine is at ambient outdoor temperature. But what is the ambient temperature when smoking is a problem, and for how long is it a problem (and does it go away quicker when driving off than when letting the car sit and idle)? Also, is there an ambient temp level at which you can start it fine without smoke being a problem?
-Dave G.
Hipine is offline   Reply With Quote
Old 12-14-2005, 03:46 PM   #4 (permalink)
sjtymko's Avatar
Vehicle: '82 300GD TD
Further to what has been said, what colour is the smoke?
ST
1982 300GD Turbodiesel
sjtymko is offline   Reply With Quote
Old 12-15-2005, 02:43 PM   #5 (permalink)
Date registered: Dec 2003
Vehicle: 300GD Cabriolet/G500
I have an 82 300gd that smoked quite a bit (grey/white in color). I tried many things (valve adjust, fuel additives, etc..., but they didn't help. Finally, I let a mechanic adjusted the timing, and the smoke was gone immediately.
slackerguy is offline   Reply With Quote
