» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 12-12-2005, 06:59 PM   #1 (permalink)
fernweh's Avatar
Date registered: Mar 2004
Vehicle: 91 300GE, W 200
Rear Axle Bearing Rotating in Axle-Housing
I'm just notified by my mechanic that I lost a rear wheel bearing and the outer race had spun in the axle housing. Anybody had the same problem and were able to fix it with the likes of a Looktite product?
Or any other suggestions?
Thanks for your help
Karl
fernweh is offline   Reply With Quote
Old 12-12-2005, 07:12 PM   #2 (permalink)
4x4abc's Avatar
Vehicle: TJ, FJ40, JGC, 280GE, G500
RE: Rear Axle Bearing Rotating in Axle-Housing
Yup, I have used Loctite before to do exactly what you have in mind.
Have fixed a spun rear race with aluminum foil as well - seams to work better than Loctite.
Harald
4x4abc is offline   Reply With Quote
Old 12-12-2005, 07:22 PM   #3 (permalink)
Dai
Dai's Avatar
Date registered: Feb 2003
Vehicle: 85 300GD 83 300TD
Using a Locktite or Permatex product to hold the bearing to the spun area would be good. Use the heavy duty Red thread locker goo.
A technique to provide a good interference fit in a damaged bearing seat area is to use a center punch and riddle the sides with punch marks evenly across the surface. This mushrooms up a little metal and can make up for the missing thousandths the housing needs to keep the bearing firmly in place mechanically. I've heard it called a "Chicago" fix. I don't know why. That and some Locktite Red might make for a safe repair. Cheaper than the overbore and sleeve approach to the problem. A suggestion...
-Dai
Dai is offline   Reply With Quote
Old 12-13-2005, 06:15 AM   #4 (permalink)
fernweh's Avatar
Thank you guys for the input! I had the center punch modification thing in my mind too - but did't know if the precedure was forum approved [:D]
This bearing failt within 600mi - no clue what the mechanic-hack did........
Thanks again
Karl
Old 12-13-2005, 07:38 AM   #5 (permalink)
4x4abc's Avatar
bearing failed within 600 miles of what? After installing it? Sue him out of business!
Harald
Old 12-13-2005, 08:30 AM   #6 (permalink)
4x4rancher's Avatar
Date registered: Jan 2004
Vehicle: 230 G BGS 300G TDI
Can you get "LOY" plastic metal over there, ideal for this job, you can even machine it if you wish.
Just googled it to find it is sold in the USA under the Caswell brand name.
4x4 Rancher
300D Turbo Intercooled
4x4rancher is offline   Reply With Quote
Old 12-13-2005, 11:05 AM   #7 (permalink)
Hipine's Avatar
Date registered: Nov 2002
Vehicle: 1980 LWB 280GE
fernweh - 12/13/2005 7:15 AM
....no clue what the mechanic-hack did........
Better figure it out. Without taking action on root cause, the new bearing will spin in the cobbled up pocket just the same way the old one spun in the original place. Most spun races have a lack of lubricant somewhere in the chain of contributing factors.
Loctite makes specific products for the kind of repair you want to make. At least use the right product, rather than something designed as a thread locker. Find a full line distributor in your area and talk over potential solutions with them.
-Dave G.
Hipine is offline   Reply With Quote
Old 12-18-2005, 04:23 PM   #8 (permalink)
fernweh's Avatar
Thanks Dave,
I took some pictures of the remaining bearing parts.
(how can I upload them into my posts?)
Both races are still in one piece (each) but all the rollers are spewed out. This all happened appr. 600mi after a mechanic replace bearings and seals on both sides. I had a oily/moist brake carier and thought first it was a leaking wheel cylinder - but it was a tiny axle-oil leak. now this......
There was also plenty of gear oil in the axle - the failed bearing had suffient oil to work - no offroad just a bit around town driving and one trip to Seaworld San Diego - can't find any root causes.
Karl
Old 12-18-2005, 04:27 PM   #9 (permalink)
~BANNED~
DUTCH's Avatar
Vehicle: 2000 G500 NMLE & 2007 ML320 CDI
fernweh - 12/18/2005 7:23 PM
Thanks Dave,
Karl
Several sets of instructions here:
http://benzworld.org/forums/forums/f...iew.asp?fid=48
DUTCH is offline   Reply With Quote
Old 12-19-2005, 06:20 AM   #10 (permalink)
fernweh's Avatar
OH - that easy........
Thanks guys - here's a pictures
