» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 12-10-2005, 07:28 AM   #1 (permalink)
Date registered: Aug 2004
Vehicle: 1982 300gd
clutch master cylinder&slave
The problems persist after numerous attempts to bleed the hydraulic system ,I still have no clutch pressure and the realization is I need the master and slave cylinders replaced.I located the parts numbers but I want to be sure, I've only used my epc a few times.
Vin#Wdb46031217021067
master cylinder-A0012958006
slave cylinder-A0002957607
And could someone recommend a supplier or any other direction I could take .
thanx
scott
aggragated is offline   Reply With Quote
Old 12-10-2005, 07:36 AM   #2 (permalink)
~BANNED~
DUTCH's Avatar
Vehicle: 2000 G500 NMLE & 2007 ML320 CDI
RE: clutch master cylinder&slave
aggragated - 12/10/2005 10:28 AM
thanx
scott
Unless you have large amounts of fluid in the bell housing, your slave is probably OK; although, if you're doing one, you might as well do the other, too.
DUTCH is offline   Reply With Quote
Old 12-10-2005, 07:43 AM   #3 (permalink)
cashieu's Avatar
Date registered: Dec 2002
Vehicle: 200D, 300TD, 230GE
aggragated - 12/10/2005 8:28 AM
thanx
scott
Scott,
The parts are pretty pricey. Europa normally has them in stock, but it is over $400 for the pair. Depending on the currency its about $150 for the slave and about $250 for the master. Mark (Inkblotz) recently found a slave cylinder from a more common Mercedes that crosses. I believe it was from an early 80s 240D. It was much cheaper and more readily available. Hopefully he will chime in. I dont remember anyone finding a cross for the master cylinder, but maybe someone will. If you dont need it right away (perhaps you have another vehicle) I'd try Sean (Eurotruck) in GA. He's on this forum.
Bruce
Bruce Johnson
Flagstaff, AZ
cashieu is offline   Reply With Quote
Old 12-10-2005, 07:55 AM   #4 (permalink)
Hipine's Avatar
Date registered: Nov 2002
Vehicle: 1980 LWB 280GE
I hate to suggest it, but maybe try a pressurized "back bleed". For this one you open the bleeder screw on the slave, firmly attach a hose (like with a wire tie as a clamp) and then force fluid backwards through the system up to the master cylinder.
Sometimes this way will dislodge a bubble that was trapped while bleeding the normal direction.
Another place to look is inside the bulkhead where the pedal rod comes through from the MC. If you see any fluid there, it's the MC.
It might also work to just disassemble and thoroughly clean the master cylinder. I did that for a guy who had your symptoms a few years back. The fluid in his reservoir was black and cruddy and full of little rubbery chunks. One of those chunks had lodged in the seal preventing full pressure build up. The seal itself was fine though. If your fluid is gunky like that, a good cleaning with denatured alcohol might do the trick.
Check the prices again, but last time I did, a rebuild kit was not cost effective, it was only a few dollars more for the whole assembly, and that of course got you a new cylinder bore, which can be a part of the problem. Though if you went the cleaning route first, you'd know the condition of your bore for sure.
And don't discount the other poster's reference to the flex line. If I was going to the trouble to do new master and slave, I'd certainly do teh flex line too.
Good luck!
-Dave G.
Hipine is offline   Reply With Quote
Old 12-10-2005, 08:08 AM   #5 (permalink)
Vehicle: 2000 G500
These folks can be pricey, but their solutions are excellent.
http://www.whitepost.com/brake.html
S,
J.R.
2000 G500 LWB Obsedian Black
2005 Toyota Tacoma 4.0 liter
1993 240DL Anthracite
1986 280GE LWB Anthracite (Sold, and part of me wishes I hadn't)
1980 450SEL retired after 15 years of faithful service
JRBrown is offline   Reply With Quote
Old 12-10-2005, 09:08 AM   #6 (permalink)
inkblotz's Avatar
Date registered: Apr 2005
Vehicle: 1983 300GD Turbo Cab, 98 E320 Wagon
RE: clutch master cylinder & slave
I purchased the Clutch master direct from the local Mercedes Dealer (they happened to have it in stock). The part number is A 001 295 8006 I got a good deal at the time $141.44. The regular price was $262.47 from the dealer. Sean's price @ Eurotruck was about the same maybe a little less. I would have bought it from him but he was out of stock @ the time. I will do some looking into the slave cylinder. That part was fairly generic to many Mercedes I believe the 240D was on the list. The main thing to look for was the bolt pattern they were not @ 12:00 and 6:00. It was more like 12:00 and 5:00.
Mark
inkblotz is offline   Reply With Quote
Old 12-10-2005, 09:21 AM   #7 (permalink)
~BANNED~
DUTCH's Avatar
inkblotz - 12/10/2005 12:08 PM
The main thing to look for was the bolt pattern they were not @ 12:00 and 6:00. It was more like 6:00 and 2:00.
Mark
That depends on the transmission. The 4 speed is 12 & 6. The 5-speed is 12 & 4 (2 & 6[;)]).
Old 12-10-2005, 09:26 AM   #8 (permalink)
inkblotz's Avatar
Correct.
Old 12-10-2005, 09:34 AM   #9 (permalink)
Vehicle: 1982 300gd
I just came from the dealer and he confirmed that he had the available part #s in his system but that he would have to contact Germany to verify and order it(4+ days)[:(] $226.24 master cyl
Mark, I checked your previous post about the 240d slave cylinder interchange but I was under the impression it would only work for your 5 spd . If I could use that on my 4spd it would definitely help.
If anyone has any repair kits that would fit my setup PM me.
I'll try contacting Sean at Eurotruck
thanx
scott
Old 12-10-2005, 10:08 AM   #10 (permalink)
4x4abc's Avatar
Vehicle: TJ, FJ40, JGC, 280GE, G500
the fact that the order numbers do not start with "460" tells us that they are interchangeable parts between models.
Harald
4x4abc is offline   Reply With Quote
