» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 10-03-2005, 10:14 AM   #1 (permalink)
4x4rancher's Avatar
Date registered: Jan 2004
Vehicle: 230 G BGS 300G TDI
Bad Vibrations
Guy came by with a G 230 today, tearing his hair out about the vibration he was getting from his G.
Had been to a MB dealer who had quoted him the cost of buying a small country to replace props rebuild axles etc etc.
Real fault found in 10 minuets and here is the picture of the problem.
Cost to fix, a large drink in a quiet pub, after a good steak of course.
4x4 Rancher
300D Turbo Intercooled
4x4rancher is offline   Reply With Quote
Old 10-03-2005, 10:52 AM   #2 (permalink)
Date registered: Apr 2005
RE: Bad Vibrations
OK, I'll bite, what is it?
mistel is offline   Reply With Quote
Old 10-03-2005, 11:15 AM   #3 (permalink)
kashi123's Avatar
Date registered: Mar 2004
Vehicle: 1989 300GD SWB
RE: Bad Vibrations
That is an engine mount, if I'm not mistaken[:D]
I have 2 brand new ones lined up to go into my converted G at one point as per 4x4ranchers recommendation. Better safe than sorry[;)]
Richard
kashi123 is offline   Reply With Quote
Old 10-03-2005, 11:22 AM   #4 (permalink)
Ernest T Bass's Avatar
Vehicle: 280 ges 1989
RE: Bad Vibrations
Ok I’ll guess: rear rubber mounting A460 240 57 18 – only a guess though
Ernest T Bass is offline   Reply With Quote
Old 10-03-2005, 11:43 AM   #5 (permalink)
UG
UG's Avatar
Date registered: Jan 2003
Vehicle: 83 GD300
RE: Bad Vibrations
That is the gearbox support rubber. Can't figure out why those wheel bolts are in the picture.
The mount isn't cheap though. Just a pint wouldn't do it...
-UG-
UG is offline   Reply With Quote
Old 10-03-2005, 02:18 PM   #6 (permalink)
4x4rancher's Avatar
RE: Bad Vibrations
UG - 10/3/2005 6:43 PM
-UG-
UG gets the prize,Kashi, close but no cigar,(hows married life?) it's a gearbox mount, wheel bolts just happen to be on the bench and the 300 autobox just happens to be on the floor.
They aren't that expensive, and here a large drink is more than a pint.
Old 10-03-2005, 02:22 PM   #7 (permalink)
kashi123's Avatar
RE: Bad Vibrations
So I was mistaken[:I] I'll get there one day.......[:D]
Old 10-03-2005, 02:29 PM   #8 (permalink)
DUTCH's Avatar
Vehicle: 2000 G500 NMLE & 2007 ML320 CDI
RE: Bad Vibrations
4x4rancher - 10/3/2005 4:18 PM
-UG-
aka the rear engine mount. I replaced one on my 280GE and it made a major improvement in vibrations. The rubber on mine had turned to mush from leaking ATF and heat from the front muffler which was directly under it.
DUTCH is offline   Reply With Quote
Old 10-03-2005, 02:30 PM   #9 (permalink)
4x4rancher's Avatar
RE: Bad Vibrations
You were in the right area, and if you grease your props as often as you say now you would have seen it.
First thing to look for when the vibrations set in, worn out mounts. Whats this I hear, Marshaling at Landrover events, Havent the G police been round to see you yet??
