» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 09-16-2005, 01:38 AM   #1 (permalink)
ewalberg's Avatar
Date registered: Jul 2003
Vehicle: 00 g500
Why the inconsistencies on tread shape for a tire?...
A while back i was looking at BFG MTR's and noticed that the tread blocks are not all the same size. What i mean is if you look at a tire and rotate it, you'll notice that traveling around the circumference (the outside diamater) the blocks get longer and shorter as you move around the tire. I'm not just talking about the every-other-one spacing of inboard and outboard blocks, i'm talking about un-expected differences between blocks on the tire that you would expect to be identical. If this doesn't make sense i can take a picture.
I've since noticed this on the BFG A/T's also.
Anybody know why they actually do this?
ewalberg is offline   Reply With Quote
Old 09-16-2005, 04:20 AM   #2 (permalink)
Date registered: Apr 2005
Vehicle: 1984 300GD 5 DOOR
Send a message via MSN to kerry460
RE: Why the inconsistencies on tread shape for a tire?...
G,,day the answer simply is ,noise ,drumming ,harmonics ,vibration ,with large open tread pattern if all tread blocks are the same they set up a hum ,or worse .explanation may not be technicaly exact but i hope close enough to explain .kerry
kerry460 is offline   Reply With Quote
Old 09-18-2005, 12:14 PM   #3 (permalink)
Dai
Dai's Avatar
Date registered: Feb 2003
Vehicle: 85 300GD 83 300TD
Makes sense to me Kerry.
Eric, how do you like the BFG AT's? When new they are a bit squirmy on the road but that doen't last long. Are you happy with them?
-Dai
Dai is offline   Reply With Quote
