Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 09-28-2004, 03:28 AM   #1 (permalink)
Date registered: Apr 2004
Vehicle: 1980 250GD Cabrio
What is a 300GD Cabrio worth?
I am considering parting with my current G. Since I am moving from southern Fl to southern Wisconsin, I expect that a hardtop would be slightly more comfortable during the colder months. Can anyone give me an idea what a 300GD, 5-speed, leather Recaro front seats (no rear seat), 120k miles would be worth? In general the body is in good condition but there is a little rust around the bottom of the doors.
engnenk is offline   Reply With Quote
Old 09-28-2004, 05:43 AM   #2 (permalink)
Date registered: Jun 2003
Vehicle: 2000 G300 TD
RE: What is a 300GD Cabrio worth?
What year? A 463 or 460. I presume from the fact that it is a 300GD and not a G300 that you are talking either a late model 460 or early 463?
Any in what country?
GWOA Administrator
G-Wagen Owner's Association
http://www.gwoa.co.uk
Maxwell Smart is offline   Reply With Quote
Old 09-28-2004, 06:41 AM   #3 (permalink)
Actually it is an early model 460 that is currently residing in the US.
Old 09-28-2004, 09:06 AM   #4 (permalink)
Thomas.Schumacher's Avatar
Date registered: Dec 2002
Vehicle: 1985 300GD LWB 5 Speed
The five speed is a plus but may not be as durable as the four speed. The rust is a big minus. If I were buying a vehicle that showed rust, I would be checking everywhere else: under floormats, in the wheel wells front and back, tail light and rear gate frame, inside bumpers and spring towers, etc. If it has been in salt the fuel tank may show some rusting on the top side.
The condition of the top and interior is also a big issue, since both are expensive. Sun burned interior parts may be very difficult to find. Also, with 120,000 miles, there may be some front end service due, as well as timing chain/rail R/R needed.
If everything works and shows some pride of ownership it could be worth 11,000 - 15,000$US, if rust is truly minor and very much isolated to the areas noted. Without rust and in near perfect condition with long long term records and documents, it could be worth significantly more.
You might think of just adding a hardtop. For 2000-3000$ for a used hardtop (they do show up now and then) you could make the vehicle much tighter and comfortable. Wisconsin can get fairly cold in mid winter. A block heater is a must have addition.
Do you have any pictures. Also, check the posts on the GClub, here are a number of 460's for sale there most of the time.
Best of luck in your adventure northward.
Thomas
Thomas.Schumacher is offline   Reply With Quote
