I might have asked this before, but had ocaision to bump against it again and thought I'd ask again.
If I know only the SA number for some given equipment option, is there any way to get the EPC to show me all the parts that were fitted when that SA was ordered?
Dave,
I use the Find SA function by pressing F10. The EPC will prompt you for the SA number and will take you directly to the respective diagram where you can click on each part. From there you follow the footnotes according to your particular G and see what parts you are supposed to have.
With the Unimogs, picking the correct parts can be very tricky at times. Haven't spent much time on the G EPC, so I can't tell you much there.
If you find a better way, I'd love to hear about it.
My specific issue is this. I bought some wheel arch liners for my G, but the only part numbers I had were for the tubs tehmselves. I figured I could put something together myself for the mountings. But when it came right down to it, I decided I'd rather try to get the factory parts than cobble something together.
So I figure I can look up the tubs, and when I find them, the EPC will tell me what SA they're a part of, and then I can use your technique to make sure I'm seeing all the mounting hardware, and any other SAs that go along with.
