Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 04-11-2004, 02:43 PM   #1 (permalink)
Date registered: Jan 2004
Vehicle: 1980 230G Cab 4spd
Removing dashboard top.(460)
the top of the dashboard on the right side with the grab handle on a 460 (I have a 1980 cab)...how do you get this off? I can't see any screws or attachment points anywhere...
thanks
George
Gkase is offline   Reply With Quote
Old 04-12-2004, 01:06 AM   #2 (permalink)
G Dane's Avatar
Date registered: Dec 2003
Vehicle: 1981 SWB 300GD
RE: Removing dashboard top.(460)
Hi
First remove the glove compartment- remember the bolt underneath, where the tools are straped up. Then reach your hand in the hole and feel the bolts that holds the "panic" handle and in the far corners with some light in the hole, you will see the tiny bolts that holds the whole vinyl top of the dashboard. It´s a small space to work in, but I managed to pull it off without removing the center console with radio and heater[:D]
P.S. Be carefull not to tighten the screws for the glove conpartment too much- the plastic is known to splinter very easy...[:o)]
Peter
G Dane is offline   Reply With Quote
Old 04-12-2004, 05:56 AM   #3 (permalink)
Thanks Peter!
