Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 03-15-2004, 07:13 AM   #1 (permalink)
Date registered: Sep 2003
Vehicle: Current: 1966 230S 02 G500 1959 190SL 00-02 SL600? 09 G550?
Help from somebody w/ the EPC?
My rear tire is getting removed from the rear door - hopefully this week. I've looked at several pictures of Gs w/o the rear mounted tire. They all have some body plugs of some type in the 3 holes that will remain. They all looked to use identical plugs from the photos. Before I spend some time at the body supply shop maybe these are a MB part?
Can somebody check their EPC? There should be 3 plugs, and it looks like the top one (overlaps the ridge in the door) may be a different shape/part #.
Thanks,
Dave
<BR>
<img src="http://www.benzworld.org/gallery/data/10323/99695011425282006104637AM.JPG_old">
<BR>
Search first, ask second.
mb230s is offline   Reply With Quote
Old 03-15-2004, 11:34 AM   #2 (permalink)
~BANNED~
DUTCH's Avatar
Vehicle: 2000 G500 NMLE & 2007 ML320 CDI
RE: Help from somebody w/ the EPC?
mb230s - 3/15/2004 9:13 AM
Thanks,
Dave
My EPC does not show and plugs for the holes - only the attachment hardware.
Where are you going to carry the spare? You are aware that the mount can be lowered to improve the view out the back?
DUTCH is offline   Reply With Quote
Old 03-15-2004, 11:39 AM   #3 (permalink)
79percent's Avatar
Date registered: Oct 2002
Vehicle: W463, 300GE
Send a message via MSN to 79percent
Dave,
I've checked EPC, couldn't find it. could be some other Seals or plugs, or just in different group numbers...
Mit freundlichen GrĂ¼ssen
Klaus, formerly known as 300GE
http://www.gwagen.de
79percent is offline   Reply With Quote
Old 03-15-2004, 12:11 PM   #4 (permalink)
Lower would be nice to impove visability, but I have another problem.
I street park the G in Chicago. There are a lot of people that can't parrallel park and use your bumper as a parking guide. That stupid hard shell sticks out farther than the bumper and is too fragile to survive any impact. Mine has been dented twice, and I'm sure many more will follow. It looks like crap.
Also, I have a hitch mounted bike rack which I use quite a bit. It doesn't clear the tire either.
The tire will be moved inside, possibly mounted on-end above the CD changer. If it can't be made to fit there I'll just lay it in the back.
Old 03-15-2004, 05:46 PM   #5 (permalink)
Date registered: Jan 2003
Vehicle: '82 300gd
I think there is an adaptor plate available to move the hitch rearwards a few inches,possibly item 3008 on this page
http://www.g-center.nl/index.php?page=parts&cat=3&l=1
they also do the wheel lowering brackets,and would you go for a non-fragile fabric cover,or if it is an alloy wheel leave it uncovered.Just ideas as opposed to losing the interior space.
bob
whelanrob2002 is offline   Reply With Quote
