Warning: parse_url(http://) [function.parse-url]: Unable to parse URL in /includes/init.php(329) : eval()'d code on line 37
Maintanance - Benzworld.org - Mercedes Benz Discussion Forum
» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > G-Class
Old 01-23-2004, 08:30 PM   #1 (permalink)
Kuzuki
Kuzuki's Avatar
Date registered: Jul 2003
Vehicle: 1986 280 GE lwb
Send a message via ICQ to Kuzuki Send a message via MSN to Kuzuki
Maintanance
Next week I'll have the front and rear axle bearings replaced on my G. Also all fluids/filters will be changed and the rear driveshaft will be sent to a machineshop to get balanced (the front was already done couple of month ago and the change was amazing).
Is there anything else that should be done on the G while in the shop? Any special preventive maintanance?
Thanks,
Mike
Mike
280GE
Kuzuki is offline   Reply With Quote
Old 01-24-2004, 05:37 AM   #2 (permalink)
Iver460
Iver460's Avatar
Vehicle: '82 300 GD Cab STT ('02 G270CDi/'85 300 GD SWB)
Send a message via MSN to Iver460
RE: Maintanance
Put a gardening hose on the top and bottomn round of your new springs. That will prevent the springs from making noises when they move around in the spring seat.
www.g-wagen.no
Iver460 is offline   Reply With Quote
Old 01-24-2004, 01:38 PM   #3 (permalink)
Toronto230GE
Toronto230GE's Avatar
Date registered: Nov 2003
Vehicle: 230ge
RE: Maintanance
You can do that but if you are removing the springs why not plastic dip..there is a ruberized coating you can purchase from Eastwood that is flexable and chip resistant. It comes in cool colours too! http://www.eastwoodco.com
1987 230GE
2002 VW EUROVAN GLS
2002 MB G500
Toronto230GE is offline   Reply With Quote
Old 01-24-2004, 01:40 PM   #4 (permalink)
79percent
79percent's Avatar
Date registered: Oct 2002
Vehicle: W463, 300GE
Send a message via MSN to 79percent
RE: Maintanance
Iver Dybwad - 1/24/2004 8:37 AM
only problem with : moisture can get trapped there and force springs to corode. After a while, springs will break.
RGDS
Mit freundlichen GrĂ¼ssen
Klaus, formerly known as 300GE
http://www.gwagen.de
79percent is offline   Reply With Quote
Old 02-03-2004, 07:24 PM   #5 (permalink)
Kuzuki
Kuzuki's Avatar
RE: Maintanance
Looks like I'll have my G siting in the shop for a while as the local DC dealer has no rear axle seals available. They will order them thru DC in Guatemala wich hopefully should not take longer than 2 weeks. All other seals were available and the bearings were bought elsewere. Will have the CV joints checked out at a specialty shop, greased and booted.
Mike
