| Inner and outer brake pad wear
fellow owners-My 2005 cdi has 159000 miles on it. I've changed the pads once (front at 91,000, rear at 75,000) and have the orig rotors. I drive out west a lot from Florida and other highway driving. I just checked the fronts with the idea of doing a complete brake job (rotors, pads, fluid, wheel bearings) and noticed on the front, the inner pad on both sides is considerably more worn than the outer pads. Both have worn about the same, the inners are about 1/8 in and the outers maybe 1/4 in. The rotors are just within spec (25.4) so I will do rotors also. I will do the job in the next month or so but wonder why the inners wear so much more. Checking one set of the old pads that I had kept, the same situation. Everything works well, just curious. The replacement pads are MB from the dealer. steve
