New after-market wheels - problem with grease caps ... - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 02-17-2012, 11:47 PM Thread Starter
Date registered: Jul 2009
Vehicle: 2009 Audi S5 4.2L 2006 Mercedes CLS 500
Hi all,
I don't know much about wheels, spacers & off-sets but I'll try to explain my problem as best as I can.
Recently I had to buy all 4 wheels for my 2006 W219 in a hurry because one of the wheels was bent and shop couldn't find a single matching rim. The new wheels are after-market wheels and after installation grease caps do not look right to me. The front cap is sticking out too far and I cannot put any center cap on it. Please look at the picture of front wheel. Someone told me that I need a hubcentric spacer to fix this issue, is this correct? Does anyone know what size (thickness 115mm etc) spacers would I need? Is there any thing else that I need to be careful about while shopping for spacers, for example new longer lug-nuts (how long would be enough)?
Now yesterday I took off the center cap from rear wheel to see how do rear wheels look & how did shop managed to put on center caps on rear wheels and to my surprise, there was no grease cap on rear wheel. I am attaching the picture of rear wheel with center cap removed. What do you think about it. Do I need to put new grease caps on rear wheel or does it look ok to you experienced users?
Thank you.
ID:	427077   Click image for larger version
Raindrop is offline
post #2 of 10 (permalink) Old 02-23-2012, 08:48 AM Thread Starter
I was wondering if anyone has any opinion or any pointer regarding this issue?
Raindrop is offline
post #3 of 10 (permalink) Old 02-28-2012, 01:38 PM
Date registered: Feb 2012
Are those the AMG replicas? Be interesting to know what you find out since I just today ordered a set of those for my W203.
jsbaker is offline
post #4 of 10 (permalink) Old 03-01-2012, 08:29 AM Thread Starter
Yeah these are AMG replicas and I think I would need wheel spacers for these wheels to look right. I'll order the wheel spacers next week and see how does it go,
Raindrop is offline
post #5 of 10 (permalink) Old 03-17-2012, 01:16 AM Thread Starter
Dealer said: No need for grease cap on rear wheels.
**Update**
Alright so was at local MB dealer and asked them for the part number for grease cap for rear wheels. They told me that rear wheel bearing unit is a 'sealed' unit and it does not need grease a cap. Although from wheel bearing unit would need a grease cap.
Has anyone else heard of rear wheels on W211 or W219 vehicles not needing a grease cap?
Raindrop is offline
post #6 of 10 (permalink) Old 03-17-2012, 01:23 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Originally Posted by Raindrop View Post
**Update**
Most rear-wheel drive vehicles do not have grease caps on the rear wheels. It's just a completely different design, different types of bearings, etc.
The wheels you bought are the wrong offset, which is why the grease caps are sticking too far out. You will indeed need spacers on the front, and you will also need extended lug bolts. Work with a good wheel shop to make sure they don't screw it up. The bolts need to be the right length and the mating surfaces have to match. Conical seat, ball seat, radius of ball seat, etc.
Good luck.
Check Codes is offline
post #7 of 10 (permalink) Old 03-23-2012, 05:00 AM
Date registered: Jul 2010
Vehicle: 2008 E320 Bluetec
I had the same issue with those wheels. I measured how far the cap stuck out from the fully seated position and ordered spacers for the front that we're at least that thick along with needing new lug bolts that were the same amount longer. In my case I used 5mm spacers and the caps are a tight fit. Although I only needed them for the front I now think I should have put some in back just to make the offset look the same in the rear. Having said that, since 5mm isn't that big no one else seems to notice the difference.
Fadsbobo is offline
post #8 of 10 (permalink) Old 03-23-2012, 06:30 AM
Date registered: Mar 2012
What I have done in the past. Was to modify the cap. "with a hammer"!! sounds a little primitive but it dents the cap just enough to get your center cap on. Try this before your spend money on spacers. Spacers are bad,unless you get the "hub centric" spacers but no one that I know of makes a 5mm hub centric spacer. If they are not it will likely to cause vibrations and you lose 5mm of your lug bolt.
rdprograma is offline
post #9 of 10 (permalink) Old 03-23-2012, 06:38 AM
Agree the hammer helped a little but not enough to make up the 5mm needed. I used H&R hub centric spacers made specifically for MB. I also run my Porsche at the track and lots of guys run H&R hub centric spacers made specifically for their Porsches.
Fadsbobo is offline
post #10 of 10 (permalink) Old 03-26-2012, 08:07 PM
Date registered: Jan 2012
Vehicle: 1991 300ce
Quoted: 2 Post(s)
first of all, your car never came with grease caps in the rear from factory. secondly, stay away from spacers unless you really want those wheels. its not the offset that is the problem. its the wrong front wheel size for that car.
benzdok is offline
  Mercedes-Benz Forum > Mercedes-Benz Technical Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
    Centra wheels center caps wheels euroamg W126 S,SE,SEC,SEL,SD,SDL Class 0 04-22-2010 12:53 AM
    Grease Those Wheels Now !!! kdbcom W245 B-Class 28 11-19-2009 05:38 PM
    Headlight relay connection problem... Conductive Grease? JohnHunt W126 S,SE,SEC,SEL,SD,SDL Class 5 07-19-2009 01:51 PM
    Good weather + elbow grease = clean wheels lastprodigy W163 M-Class 10 03-12-2007 05:51 AM
    FS: AMG caps for AMG Penta wheels marlinspike For Sale/Wanted/Trade/Giveaway 5 12-23-2006 07:13 PM
