Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
Old 09-27-2006, 10:21 PM   #1 (permalink)
orangebang49's Avatar
Date registered: Jul 2006
Vehicle: 2005 c230 kompressor sport sedan
clanking / knocking noise
Just put on new wheels. 19*8F & 19*10R..........First problem i had was the lugnuts were to long on the rear wheels. made a noise from the parking brake in the rear hubs..... solved that with shorter lugnuts. but now i hear a clanking/ knocking noise whenever i reverse the car, sounds like its coming from the rear...........any ideas what the noise could be? driving is fine, no noise...... I have a 2005kss.........
orangebang49 is offline   Reply With Quote
Old 09-28-2006, 06:01 AM   #2 (permalink)
BenzWorld Tire & Wheel God
sounds like you have damaged the parking brake assembly .... I have seen it many times before and it is always described exactly like your description
<img src="http://WWW.TIRERACK.COM/posting_banners/luke_mercedesshop_mbworld.jpg">
Luke@tirerack is offline   Reply With Quote
small knocking noise ? Zapmehome W211 E-Class 8 09-12-2006 11:55 AM
Clanking noise from rear of 300TE: What's the source? ron in sc W124 E,CE,D,TD Class 2 01-22-2006 12:32 PM
Knocking noise LordNikonXTC General Mercedes-Benz 1 12-02-2005 10:47 PM
04 ml500 clanking noise pointman W163 M-Class 9 03-25-2005 11:43 AM
Clanking noise SteveL R170 SLK Class 3 03-22-2001 07:23 AM
