Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
Old 05-25-2004, 06:01 PM   #1 (permalink)
Date registered: Aug 2003
Vehicle: CLK 500
???? for LUKE
hi luke,
i just recently purchased some SS2 from davins, when mounting, the rims are not clearing the brake calipers.... can i get aftermarket calipers, or another route without spending alot more money... thanks... i see you sell brake kit too,,, any suggestion?
04 clk 500, davins SS2 19.8 38 offset w/ falken 235/35/19
thank you
MoNkeYsJuiCe24 is offline   Reply With Quote
Old 05-26-2004, 01:02 PM   #2 (permalink)
BenzWorld Tire & Wheel God
RE: ???? for LUKE
our brake kits would cause more issues .... did you buy the wheels from a dealer ... if so, take them back they do not fit .... if you are bound and determined to make them work look into spacers ... however I do not recommend or endorse the use of spacers in most cases .... Davin's those are spinners right ???
<img src="http://WWW.TIRERACK.COM/posting_banners/luke_mercedesshop_mbworld.jpg">
Luke@tirerack is offline   Reply With Quote
Old 05-27-2004, 12:38 AM   #3 (permalink)
Vehicle: CLK 500
RE: ???? for LUKE
ur correct about the spinners, i spoke to davin and they are kind enough to take them back,,, i just really wanted to ride with those rims.... i looked into spacer and for the front i would really need some thick one,,,,, thanks luke, ur knowledge has been a great help... thanks you for ur time..
