» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
Old 05-13-2008, 08:48 PM   #11 (permalink)
die s-klasse's Avatar
Vehicle: '02_S500
Originally Posted by Jayhawk View Post
I went from OEM 16" 225's to 245/45WR-18 Goodyear Eagle F1 GS-D3 XL front and 275/40YR-18 Goodyear Eagle F1 GS-D3 back, and Luke recommend 36 psi front and 32-34 psi back. You probably need to go a good bit higher w/ 20"s.
thanks jay as well.
i think max rating is at 40psi.
so i shouldn't go too close to 40?
die s-klasse is offline   Reply With Quote
Old 05-14-2008, 09:57 AM   #12 (permalink)
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: Mercedes-Benz
Send a message via AIM to Mercedes Benz of Florida Send a message via Yahoo to Mercedes Benz of Florida
Originally Posted by ivyknoll View Post
I recently bought new tires for my 2002 E320. The tire dealer set the pressure at 40psi as the max rated psi for the tire is 44. He said they will run cooler and therefore last longer. However, the car rode like a truck and the handling seemed almost unstable at interstate highway speeds. So, I lowered it to MB's recommended full load pressure of 28 front and 34 rear and the ride and handeling are now as they should be.
My question, who's really right? Seems that tire dealers and auto manufactures have never agreed on the correct psi.
The correct one is the Manufacturer.
They are the sole authority in these matters.
And the 28 Front/34 Rear is right.
I agree your PSI was way too high.
( now in my case, I bump up the PSI +5PSI in front and rear )
That's a personal choice and there is no degradation in handling or
responsiveness.
Charles
Orlando, Florida
United States of America
Mercedes Benz of Florida is offline   Reply With Quote
Old 05-15-2008, 05:46 AM   #13 (permalink)
BenzWorld Tire & Wheel God
responsiveness.
a couple of things
there is no sole authority ... the Mercedes OE recommendations are a compromise between handling and ride quality which they feel will be best suited to a majority of drivers while maintaining proper load capacity.
and your personal +5 psi would not only NOT degrade the handing and responsiveness it would improve both
Luke@tirerack is offline   Reply With Quote
Help with correct tire pressure SL600-nut R129 SL Class 2 01-20-2007 03:35 PM
Correct Tire Pressure For 2003 Sl500? trippert R230 SL Class 4 01-20-2007 07:08 AM
Correct tire pressure jtbeche W208 CLK Class 14 06-29-2005 03:58 PM
correct tire pressure W140Gill The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 06-12-2003 08:14 AM
What is the correct tire pressure for the ML 320? RedDevil W163 M-Class 7 07-23-2002 07:11 PM
