Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
Old 02-24-2006, 02:28 PM   #1 (permalink)
smurfccoupe's Avatar
Date registered: Apr 2003
Vehicle: 2002 C230
Luke, suggestions on tire size for 18" Ultraleggeras
Luke, just bought one of these from you guys, and if it's kosher, will be completing the set. You guys recommend 225/40s for it. Do you know if going a little wider is possible for the rears, or would you recommend I stick with the 225s?
Also, looking for a max traction summer tire. I'm guessing that you'll be recommending Eagle GS-D3s, but I was thinking about Yoko AD07s instead, as I'd be willing to trade a little wet traction for max dry traction. Thoughs?
Thanks!
2002 Ccoupe, not as good as others, apparently
smurfccoupe is offline   Reply With Quote
Old 03-07-2006, 07:47 AM   #2 (permalink)
Vehicle: 2002 C230
RE: Luke, suggestions on tire size for 18" Ultraleggeras
Luke, any ideas? I'm getting the remaining three rims today, so will be ordering tires shortly.
Thanks.
