Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
Old 07-14-2005, 12:56 PM   #1 (permalink)
Date registered: Jul 2005
20" on a 96 sl500 R129
will the following wheel and tire setup fit my 96 sl500?
20x8.5 front
20x9.5 rear
35mm offset
5x112mm pattern
245/35/20
245/30/20
Horus is offline   Reply With Quote
Old 07-18-2005, 03:30 AM   #2 (permalink)
RE: 20" on a 96 sl500 R129
i don't know man i got the same qwestion will a 255/35/20 fit on my 126 560 sel ???? [:(] and nobody is answering me [xx(] i whant omega jupiter 20x8,5
M_v_P is offline   Reply With Quote
Old 07-22-2005, 01:13 AM   #3 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
Date registered: Jul 2004
Vehicle: SL, CLK & 5E's
Horus - 7/15/2005 8:56 PM
20x8.5 front
20x9.5 rear
35mm offset
5x112mm pattern
245/35/20
245/30/20
Horus I do not advise on fitting 20's at all, however here's some info which might help you make a better choice:
Bolt Pattern: 5x112
Offset Range: 19 to 25
Wheel Size Range: 17x8.0 to 19x8.5
OEM Tire Size (Front): 245/45-17 (245x652 mm)
OEM Tire Size (Rear): 275/40-17 (275x652 mm)
Max Tire Dimensions: 255x667.0
I'd say go for 8.5x19's (ET19-24) with 255/35R19's up front and 9.5x19 (ET32-36) with 285/30R19's at the rear if you want a "big wheel" setup on your R129.
Good Luck.
M_V_P I have just replied to your question on the other thread.
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/global/stations/41571.gif"border=0>
<img src="http://www.danasoft.com/vipersig.jpg">
Storm. is offline   Reply With Quote
