How to fix minor cosmetic damage - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-20-2011, 09:37 AM Thread Starter
Date registered: Jan 2010
Vehicle: 2000 and 2003 W220 S500
Baltimore is a regular city and like all regular cities, it has regular idiots.
One of these idiots decided that a rock would make a nice dent in my car.
This is how to make that go away. (The damage, unfortunately, not the idiots.)
1. The first thing you need to do is asses the damage. This was made by a marble brick corner smashed into my passenger side door. It made a dent about 1 1/2 inches in diameter and about 1/4 inch deep. I taped off where I thought the damage might be, so that I don't sand anywhere extra I don't have to.
2. You need 600 grit sand paper and a flat sanding block. What this does is three things:
Remove paint and cleat coat to better apply Bondo.
Show exactly how the surface is structured.
Slightly lower the surface so that the Bondo is even with the surrounding paint.
3. After sanding, you can clearly see that the metal around the main indentation is warped and needs to be sanded down to metal and bondo'd even to the surrounding metal.
4. Bondo the damaged area. Let dry and sand with 600 grit. If you do it right, you will have a perfectly smooth area that you can't feel any indentations at all in.
5. Now, you need to cover the area off. Get ready for some spray painting.
6. Dry with a heat gun or your wife's hair dryer.
7. Repeat, only now with clear coat.
8. Cure. I left this alone over the weekend.
9. If you did it right, once you peel the tape, you'll see edges as thick as the tape. That now needs to be sanded very carefully to blend in. The trick is to start in slightly inside the edge of the newly painted surface with 600 grit. That way, the paint tapers off slighly from the edge, which should now be invisible.
10. Once you can't feel the edges, sand with 1500, then 3000, until it looks like frosted glass.
11. Compound and polish. Your baby will be good as new!
Paint used:Universal Black
Clear Coat
Sandpaper used:600 grit
1500 grit
3000 grit
Compound used:Meguair's Ultimate Compund
Name:	1 The Damage.jpg
ID:	404661   Click image for larger version
Name:	2  600 Grit and Sanding Block.jpg
ID:	404662   Click image for larger version
Name:	3 Sand Flat.jpg
ID:	404663   Click image for larger version
Name:	4 Bondo The damage.jpg
ID:	404664   Click image for larger version
Name:	5 Sand the bondo.jpg
Name:	6 Cover the area.jpg
ID:	404666   Click image for larger version
Name:	7 Spray Paint Black.jpg
ID:	404667   Click image for larger version
ID:	404668   Click image for larger version
Name:	9 Compund and Polish.jpg
Gabby07621 is offline
post #2 of 2 (permalink) Old 11-07-2011, 01:04 PM
yka
yka's Avatar
Date registered: Dec 2008
Vehicle: US spec MB560SL 1986, Audi A4 2pcs, Ford Taunus 1964 17M and 2.0 1975
Quoted: 53 Post(s)
Send a message via Skype™ to yka
Thank you for detailed writing - I have to try this method with my bonnet damage. I am so proud my factory original paint and I don´t want to repaint anything more than just needed. My bonnet damage appeared during overseas container transportation.
Yka
Ei riemulla rajaa kun saa mersulla ajaa
There is rejoicing when the limit allowed to drive a Merc
yka is offline
  Mercedes-Benz Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
    nashville flood damage = electrical damage 06sport W203 C-Class 3 02-04-2011 07:08 AM
    Minor W202 Cosmetic Issues D: thepinoc W202 C-Class 19 11-01-2008 11:44 AM
    Minor bumper damage - Again SlacKeR R170 SLK-Class 6 08-31-2006 05:11 PM
    COSMETIC HELP! ttaleric W163 M-Class 3 12-10-2004 01:42 PM
    Another Look for Brabus CLK Cosmetic kit.. indra C208/A208 CLK-Class 0 12-18-2001 09:03 AM
