Clear Coat Peeling Off - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 10-18-2011, 12:41 AM Thread Starter
fata1ity's Avatar
Date registered: Jul 2007
Vehicle: 1999 E320
So for the past few months, all the Clear Coat (is what I'm guessing it is) is peeling off of all my plastic trim pieces. Front bumper, mirrors, the two trim pieces on the roof.
What causes this? How can it be fixed? How can it be prevented?
I'll try to get some pictures tomorrow.
fata1ity is offline
post #2 of 10 (permalink) Old 12-14-2011, 02:24 PM
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: 2000 Mercedes-Benz S500. Sold: 2000 C230K, Sold: 1997 Porsche 944S
Quoted: 26 Post(s)
Send a message via Yahoo to Mercedes Benz of Florida
This is caused by heavy chemicals usage and mechanical wear. In other words, it is caused by using Car Wash Drivethru.
That's a big no no.
Car Wash Drivethrus use strong chemicals and the machine they use is so abrasive it will, eventually, remove the Clear Coat paint then the Actual Paint itself.
Hand Wash is the only way to prevent it.
Charles
New York City, NY
Richmond County
United States of America
Mercedes Benz of Florida is offline
post #3 of 10 (permalink) Old 12-14-2011, 09:38 PM
Benznoob26's Avatar
Date registered: Jul 2009
Send a message via AIM to Benznoob26
I have no idea what MB of florida is talking about. The only problem with car washes are the abrasive brushes they use scratch the paint, which are hardly that noticeable..
Delamination (clear coat peeling) is irreversible, and a pita to fix. your only option is to have it sanded down and painted. I'd be careful and take it to one of the more reputable shops around you, and check their work before it's painted. A lot of places will cut corners, and your clear coat will begin peeling in a year or two.
Edit: causes include sun exposure, not keeping the car waxed, and/or the simple fact that factory paintjobs aren't perfect and the fact that the car is 12years old.
Benznoob26 is offline
post #4 of 10 (permalink) Old 12-17-2011, 05:11 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Where are the photos you mentioned?
Musikmann is offline
post #5 of 10 (permalink) Old 12-20-2011, 01:44 PM
ScapinBenz's Avatar
Date registered: Nov 2010
Vehicle: 1998 Mercedes Benz CL500
There was discussion of a similar topic in the W140 forum. If you clear coat has peeled there are a few things that may have caused it; harsh climate or exposure to UV rays a lot (especially if car is parked outside), repeated use of harsh chemicals when washing (ie Zep degreaser or something similar). Other than these things mentioned, they only real issue that would result in this is little or no maintenance of the paint, in other words, the car was probably not taken care as well as it should be. This may or may not be true, I have no idea if you are the original owner or not. These are just some ideas, so hopefully it helps. All the best.
ScapinBenz is offline
post #6 of 10 (permalink) Old 12-21-2011, 08:37 AM
ellcapitan's Avatar
Date registered: Nov 2011
Vehicle: 2003 CLK 320 Coupe
Also shoddy body repair work. Factory Benz paint should never do this with regular care, under regular conditions.
ellcapitan is offline
post #7 of 10 (permalink) Old 01-05-2012, 07:23 AM
Date registered: Jan 2010
Vehicle: 2000 and 2003 W220 S500
I've also seen clear coat peel if it was put on after the layer below it has cured for more than a few months.
Gabby07621 is offline
post #8 of 10 (permalink) Old 01-08-2012, 03:11 PM
Date registered: Jan 2006
Vehicle: 00 SL500 SOLD, 05 SL600 Sport, 09 Silverado 4x4 LTZ,SOLD '15Silverado LTZ 6.2 8Speed John Deere 318
Quoted: 2 Post(s)
The other thing that is a factor is AGE, This car is 13 years old, Depending on where the car is located, Stop and think how many heating and cooling cycles that paint has seen!!!!!!!!!!! Newer paint has become more durable over the years but it will fail sooner or later, You can protect it (by waxing and keeping it out of the sun) but it will fail at some point.
drags1998 is offline
post #9 of 10 (permalink) Old 01-09-2012, 01:26 AM
togwt's Avatar
Date registered: Jun 2007
Quoted: 2 Post(s)
That's a big no no.
Agreed (plus the other factors mentioned (i.e. UV radiation, etc) but allied with harsh chemicals found in drive through 'touchless' washing will destroy clear coat paint
~ Providing unbiased advice that Professional and Enthusiast Detailer’s Trust ~ TOGWT Blog - TOGWT Facebook Page
togwt is offline
post #10 of 10 (permalink) Old 11-19-2015, 07:20 PM
Date registered: Nov 2015
Unhappy Clear Coat peeling
My car is a 2011 c300 and it is peeling as well on the roof top plastic pieces. Not that old!
kamdean is offline
  Mercedes-Benz Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
    Peeling Clear Coat DP W126 S,SE,SEC,SEL,SD,SDL Class 25 04-04-2010 05:06 AM
    Clear Coat Peeling - WTF? alylea W163 M-Class 22 07-11-2007 01:36 PM
    peeling clear coat jv advertising Detailing and Car Care 3 02-07-2006 09:49 AM
    Clear coat peeling BackRoll23 W210 E-Class 2 12-14-2004 12:21 AM
    My @#%&%$# Clear coat is peeling off joe defrancisci W126 S,SE,SEC,SEL,SD,SDL Class 6 10-10-2002 06:24 PM
