engine wash electrical problem w203 - 2000 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-28-2011, 03:41 AM Thread Starter
Date registered: Jun 2011
HI after washing the engine of my W203 C Class 220 CDI year 2000 manual gear,
The engine does not start, what electrical problem could it be
herri is offline
post #2 of 4 (permalink) Old 06-28-2011, 07:33 AM
Date registered: Jan 2011
If you got the electronics wet, it could be a number of things, most not good. Does it make any sound? does it turn over? you have not stated any details.
ImInPA is offline
post #3 of 4 (permalink) Old 06-29-2011, 04:05 AM
togwt's Avatar
Date registered: Jun 2007
Quoted: 2 Post(s)
I can't help you as this is mechanical/electrical problem not a detailing one.
This won't help the OP however, but will help anyone who is going to clean their engine bay-
Protection of Electrical Components
The most important electrical components are sealed to be ‘water resistant’, that is to say against low pressure, water splashing encountered in the course of daily driving conditions. As long as you avoid directing a strong stream of water (or a pressure washer at close range) directly into these components, you will be fine.
Note this doesn't include components like air intakes etc...
Avoid the [I cleaned engine and now it won't start] scenario by covering electrical / electronic and various other parts prior to using any cleaning products, sprays or water. It unsure either protect with a covering and /or use WD-40 water repellent
• Alternator
• Alarm Housing
• Intercooler
• Battery terminals (if not covered already)
• Induction kit cone (if you have one)
• Coil packs
• Electronic control units (ECU)
• On-Board Diagnostics (OBD) port
• Air intake systems (exposed air filters) can be covered with plastic wrap and a rubber band
• Avoid getting water in the spark plug recesses
Notes:1. This is not an exhaustive list, nor is it marque specific, if in doubt use a water repellent (WD-40) and exercise common sense
2. Use cling-film and then tin foil for the alternator, alarm housing etc as the foil is easier to mould and has greater protection properties. I suggest you use a plastic bag for the induction kit and just wrap it tight over the end to stop any water ingress.
3. For the intercooler the best way to cover is to get a flat sheet of cardboard and just cut it to size so it fits and covers the fins. Cardboard will normally protect the fins for the duration of the washing. It will get soaked so discard after the wash.
4. If you are uncertain of how to proceed on something not included here; talk with somebody who has marque /model /year specific knowledge.
~ Providing unbiased advice that Professional and Enthusiast Detailer’s Trust ~ TOGWT Blog - TOGWT Facebook Page
togwt is offline
post #4 of 4 (permalink) Old 09-28-2011, 06:34 PM
Benznoob26's Avatar
Date registered: Jul 2009
Send a message via AIM to Benznoob26
For everyone deciding to pressure wash their engine bay the car needs to be running and avoidingdirect contact with alternators/coils/distributor/filter. I work at a body shop and we do roughly 5 cars a week. haven't had a problem in 2 years working there.
Benznoob26 is offline
  Mercedes-Benz Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
    Engine Shutdown, electrical problem ??? Baggy W210 E-Class 11 07-14-2010 05:05 PM
    2000 CLK 320 engine problem chavez_j C208/A208 CLK-Class 5 03-07-2010 07:40 PM
    92 500 engine or electrical problem xjs786 W140 S-Class 1 06-08-2007 12:24 PM
    Need help with electrical problem 2000 S500 gv7660 W220 S-Class 10 03-16-2006 11:09 AM
    2000 G electrical problem luminox G-Class 7 10-30-2005 10:25 PM
