Remove logo from trunk on CLK 500 - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-15-2010, 02:05 PM Thread Starter
Date registered: Oct 2006
Hello,
I saw another post on here, they said to use dental floss to get the logo off but I think on my car is different.
I want to remove the Mercedes logo off my trunk. I tried pulling it off gently and it looked like it is fixed to the trunk using a plastic plug stuck into a small hole carved into the trunk.
Please let me know how I could do this safely.
Thank you,
Mitchel
mitcheloc is offline
post #2 of 9 (permalink) Old 03-15-2010, 06:57 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
Leave them. There is no reason to remove the badges unless you repainting.
mr.xpowerseller is offline
post #3 of 9 (permalink) Old 03-15-2010, 08:58 PM Thread Starter
Thank you for your opinion, but I'd like to remove it for my own reasons.
If anyone has advice on how to take it out safely I would appreciate it.
Thank you,
Mitchel
post #4 of 9 (permalink) Old 03-16-2010, 09:55 AM
StarPower's Avatar
Date registered: Oct 2009
Vehicle: 2003 Lincoln LS V8
If you want to remove it, you'd have to have a body shop fill in the holes and repaint the trunk lid.
I wouldn't recommend prying on it anymore. I've seen several MB's where the ring is broken off of the star, so apparently these emblems are rather flimsy.
StarPower is offline
post #5 of 9 (permalink) Old 03-16-2010, 09:56 AM
slik560's Avatar
Date registered: Aug 2007
Vehicle: 1987 560SL / 2003 ML320 / 2006 Mini Cooper S
Quoted: 19 Post(s)
You might check one of the auto detailing forums like autopia.org or autogeek.net. Those guys have more experience at de-badging cars. I sure would'nt know where to start.
Careful, if you remove all the badges, someone might mistake the car for a Camry! Just kidding.
Kevin
slik560 is offline
post #6 of 9 (permalink) Old 03-16-2010, 11:13 AM
Date registered: Jul 2008
Vehicle: 2004 Mercedes-Benz S55 ///AMG, 2006 Mercedes-Benz E350
Quoted: 2 Post(s)
Badges are either glued on or screwed in. Glued removal is easy using a hair dryer and dental floss, the screwed in types will leave two or more holes which need to be filled in and repainted, a lot of work and new paint will never match perfectly.
Unless you have a very compelling reason to remove the badge, don't do it (as advised above from other members).
Klaus9000 is offline
post #7 of 9 (permalink) Old 03-16-2010, 05:32 PM Thread Starter
Lol @ Karburn, very funny!
Klaus9000, I don't need to repaint it, I have something to put over it
Any idea on how to carefully remove the screw? I'm wondering if I can get access to it under the "carpet" that's on the inside of the trunk lid..
post #8 of 9 (permalink) Old 03-19-2010, 11:38 AM
Quoted: 2 Post(s)
Yes you need to look behind the badge in the trunk, remove the plastic part to move the carpet out of the way.
post #9 of 9 (permalink) Old 03-23-2010, 01:48 PM
Mark Essman's Avatar
Date registered: Dec 2008
Vehicle: 2005 230 Kompressor
Post
The three-star badge on the trunk has plastic tabs inset into the trunk and attached from the trunk compartment, so you must remove the molding/paneling inside the trunk compartment to get to it. As pointed out above, if you decide to remove it, you will have to address the pre-cut holes for the star as they will be noticable.
Most trim badges (except for this one) are attached via some type of adhesive or double-sided tape. These can be easily removed with a heat gun and dental floss or a non-scratch plastic trim wedge, but your star has holes drilled into the trunk to mount it. Also the star itself is very fragile so if you do decide to remove it, use a gentle hand or it will break easily.
Nokiemon
2005 230 Kompressor SS
Mark Essman is offline
  Mercedes-Benz Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
    2006 CLK-500 Convertible Cabriolet Top Problems:Close Trunk Partition Error Code Tomcat715 C209/A209 CLK-Class 12 05-11-2016 09:33 AM
    clk 500 trunk problem noncam C209/A209 CLK-Class 10 02-25-2009 12:45 PM
    clk 500 trunk problem noncam General Mercedes-Benz 2 01-05-2009 04:01 PM
    trunk light cracked on clk 500 toysinthesun C209/A209 CLK-Class 3 12-05-2005 09:33 PM
    how to remove front mb logo pointman W163 M-Class 13 06-23-2004 02:47 PM
