» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
Old 10-28-2009, 07:52 AM   #1 (permalink)
Date registered: Sep 2009
Question How do I remove scratches from center console wood finish?
Posted to the general benz forum earlier, now posting here to the correct forum.
Hi,
I have a 2006 E350 sedan (Minnesota.) My 2 yr old daughter just scratched the finish on the simulated wood center console cover (the sliding cover over the cup holders.)
The scratches are only in the finish (i.e., the plastic laminate covering.)
Searching the internet I found the following products in a cadillac forum - the interior in CTS' is simulated wood, but with a black lacquer finish. Althought it should work the same for my MB (honey/walnut finish), but just checking if anyone has any advice.
NOVUS scratch removers
PlastiX by Maguairs
Blue magic Plastic & Plexiglass cleaner and scratch remover
Thanks in advance.
AQ
AQMBE350 is offline   Reply With Quote
Old 11-02-2009, 12:47 PM   #2 (permalink)
BenzWorld Detailing and Car Care Host
ByByeAmericanPie's Avatar
Date registered: Feb 2004
Vehicle: 1999 SLK230 Sport
I have heard of people using Plast-X. I have used this myself too and it works fairly well.
"The true delight is in the finding out, rather than in the knowing." - Isaac Asimov
'99 SLK230 Sport
'00 ML320
'95 BMW 525iA (RIP)
'99 Honda Passport
ByByeAmericanPie is offline   Reply With Quote
Old 11-05-2009, 12:01 PM   #3 (permalink)
karburn's Avatar
Date registered: Aug 2007
Vehicle: 1987 560 SL
The Meguiar's product is a good one. I have also used Plexus sprayed on a microfiber to wipe down the wood areas on my 560SL. It does not eliminate scratches, but it seems to blend them in a little. I have some actual cracks, so I will either have to refinish or replace. A little hard buffing with PlastiX and a terrycloth towel should fix it right up. Good luck!
1987 560SL
2003 ML320
karburn is offline   Reply With Quote
Old 11-06-2009, 08:49 AM   #4 (permalink)
Date registered: Sep 2008
Vehicle: 1997 E-420
On my 97 E420 I found the following.
1) If the scratches are very fine surface scratches, machine polishing with an orbital polisher (Porter Cable or equiv) foam pad and fine compound will shine it up.
2) If the scratches are deeper, use 4000 grit wet or dry paper with soapy water until the surface is uniformly dull, then polish with medium followed by fine buffing compound as above.
To do either of these means removal of the panel from the car.
I used method 1 on the upper panels around the climate control and method 2 on the remainder of the panels.
End result was a mirror finish that is stunning.
1997 E-420, Royal Indigo/Grey Leather
Raintracker automatic wiper, Rostra Precision Lumbar Support, Parrott Bluetooth Hands Free Kit, 17" chrome AMG replica wheels, Bilstein shocks, Akebono Brake Pads, smoked marker lights, Osram 65Watt H7's, H1 +90 fogs, Wilson Cell phone amp, Rear Seat Child restraint Tether, burlwood/leather shift knob, Becker Radio Aux input Mod.
e-420 is online now   Reply With Quote
Old 11-06-2009, 03:17 PM   #5 (permalink)
alexnatt's Avatar
Vehicle: 300TE E420 E320 4m
Hi,
PlastiX by Maguairs
Thanks in advance.
AQ
Unless MB has changed (and i doubt they have), you don't have simulated wood. it is actual wood veneer covered by clear coat.
1988 300TE, 260,000 miles
1994 E420, 81,000 miles
2000 E320 4matic wagon, 130k miles
1989 300se (sold)
alexnatt is offline   Reply With Quote
Old 11-10-2009, 06:58 AM   #6 (permalink)
Date registered: May 2008
This would be the best way to get a new look finish. I use a little of compound on a rag and try buffing them out, then use a polish compound followed by some layers of wax. If the scratches are deep, then I'd follow what he recommended.
Jayr0071 is offline   Reply With Quote
Old 01-27-2010, 06:55 AM   #7 (permalink)
Date registered: Jan 2010
Hi, scratches are nearly impossible to avoid, so the best thing you can do is learn how to deal with the scratches, like learning how to do simple scratch repairs. It's pretty simple; you don't have to hire a professional to do it for you.
Follow these steps:
1. Using a fine steel wool or sandpaper, rough up the scratched area.
2. Rub the whole length of the scratch. Cover both margins.
3. Make sure to rub in the direction of the wood grain, or rub in a circular motion to avoid damaging the wood and floor finish too much.
4. Dampen a soft cloth with mineral spirits. Use the soft cloth to wipe off any wood and dust particles on the scratched area of the floor.
5. Let the solution dry up on the floor. Depending on how big the scratch is, the scratch removal solution and how much of it you use, drying time may take from several minutes up to a few hours.
6. Take a fine paintbrush, dip it in the finish originally used on the floor and brush it across the scratched area. Wipe with a soft cloth.
7. Be careful and gentle when you brush in the finish onto the scratch. Too much or too little and the area will look much different from the rest of the hardwood floor. Brush in just enough finish so that it looks almost the same as the rest.
8. Give the new finish some time to dry. This may take between 30 minutes to a few hours.
More techniques to remove scratches You can find on my blog: Scratch repair guide
Jdcut is offline   Reply With Quote
Help! Need to remove scratches from center console simulated wood cover AQMBE350 General Mercedes-Benz 2 10-27-2009 10:19 AM
How to remove center console wood slonar21 W215 CL Class 5 08-07-2009 03:28 PM
Tips to remove wood center console/door panel??? draglink W124 E,CE,D,TD Class 8 10-24-2008 12:20 AM
Remove Center Console Wood mattwestm W163 M-Class 0 07-20-2007 11:49 AM
How Do You Remove Center Console Wood? Morpheus W126 S,SE,SEC,SEL,SD,SDL Class 13 01-12-2006 04:55 PM
