» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
Old 10-15-2009, 04:53 PM   #1 (permalink)
mercedesowner230's Avatar
Date registered: Sep 2009
Vehicle: SLK230 + C230
Question How can I get super glue off paint?
I accidentally had a little bit of super glue on my paint, is there any way to get that off without taking off the paint?
My cars a WIP.
Work In Progress.
mercedesowner230 is offline   Reply With Quote
Old 10-16-2009, 02:59 AM   #2 (permalink)
Observer/Master Skeptic
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: Mercedes-Benz & BMW
Use acetone very carefully
Nutz 4 Benz is online now   Reply With Quote
Old 10-16-2009, 06:18 AM   #3 (permalink)
cameraman123's Avatar
Date registered: Dec 2007
Vehicle: 2000 S500 Designo
Id first start with glass cleaner, bug and tar remover, goof off, or adhesive remover before resorting to strong chemicals.
2000 Mercedes Benz S500 Designo (Production date 7/99)
cameraman123 is offline   Reply With Quote
Old 10-16-2009, 07:58 AM   #4 (permalink)
Date registered: Nov 2004
If you have a local hobby shop ask for a bottle of CA remover. You might test it inside the trunk somewhere to make sure it does not soften the paint. Dried super glue is a tough beast and will require time to soften to remove. Acetone will definitely attack the paint unless it is immediately removed. this will not give it time to soften the glue.
mljim is offline   Reply With Quote
Old 10-16-2009, 09:38 AM   #5 (permalink)
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Send a message via AIM to Mercedes Benz of Florida Send a message via Yahoo to Mercedes Benz of Florida
Mineral Spirits will gently but very effectively remove that.
After removal of the offense, make sure you rewax that area
for protection.
Good Luck!
Use Mineral Spirits.
Charles
Longwood, Florida
Seminole County
United States of America
Mercedes Benz of Florida is offline   Reply With Quote
Old 10-16-2009, 08:39 PM   #6 (permalink)
I heard that Mr Clean Magic Eraser should take it off but doesnt it have bleach on it?
Old 10-17-2009, 11:30 AM   #7 (permalink)
I'm scared what to use because I dont want to take off the paint.
Old 10-17-2009, 03:44 PM   #8 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Personally, I wouldn't try a chemical approach as it may harm the paint. If you do chose this path, find a place, like under the hood and test an area to see if it dulls, dissoves, fogs or contaminates the paint in any way.
What I would do is sand it off. I know, that sounds way scarier, but with 1500 grit wet sand paper, lightly massage the area until it's gone and then hand buff it to a shine with some compound and then a light polish.
Old 10-20-2009, 12:38 PM   #9 (permalink)
Mark Essman's Avatar
Date registered: Dec 2008
Vehicle: 2005 230 Kompressor
Post
Yes, VERY light sanding with 1500-2000 grit wet/dry soaked in water prior to sanding, followed by a polish to remove fine sanding scratches, then finish with an LSP to protect will work the best.
Mineral Spirits will also work if used very carefully, but most other removal stuff is very abrasive or can soften the paint.
Nokiemon
2005 230 Kompressor SS
Mark Essman is offline   Reply With Quote
Old 10-20-2009, 01:43 PM   #10 (permalink)
Vehicle: 1999 SL500
Another Super Glue Question
This one may be a little trickier...anyone know if any of these remedies for removing super glue from paint will work on (gasp!) the wood veneer on the dash? The original owner of my 98 CL500 somehow thought the car would look better with add-on faux wood pieces around the A/C vents, and managed to leave a little fingerprint evidence on one of the wood pieces. I really hate to have to look at replacing just one piece of wood to get rid of it - so any advice on how to get the print off without calling someone from CSI? <eg>
Das Beste oder nichts
atruckerdaddy is offline   Reply With Quote
Pine tree glue destroyed my paint ejaahm Detailing and Car Care 9 10-05-2007 01:39 PM
Pine tree glue destroyed my paint ejaahm W124 E,CE,D,TD Class 6 10-01-2007 07:07 AM
How to: Super gloss paint work! sappster R129 SL Class 0 04-26-2006 10:22 PM
Glue on paint archangael Detailing and Car Care 2 07-23-2005 05:25 PM
anyone know how to get rid of crazy glue without scratching the paint? jackstephen W208 CLK Class 2 05-24-2004 02:53 PM
