» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
Old 08-31-2009, 11:11 AM   #1 (permalink)
lockmanmd's Avatar
Date registered: Apr 2006
Center air vent
The center air vent on my 05 CLK 500 has a sticky film on it. Could be from the hot weather. Any idea how to remove it.
lockmanmd is offline   Reply With Quote
Old 09-01-2009, 01:28 PM   #2 (permalink)
BenzWorld Detailing and Car Care Host
ByByeAmericanPie's Avatar
Date registered: Feb 2004
Vehicle: 1999 SLK230 Sport
Not sure what might be causing that. I would remove the vent in its entirety and soak it in some type of cleaning solution such as Simple Green or Adams All Purpose Cleaner followed by a good rinse. You might also get in there with a detail brush or small toothbrush and work over the surface too.
"The true delight is in the finding out, rather than in the knowing." - Isaac Asimov
'99 SLK230 Sport
'00 ML320
'95 BMW 525iA (RIP)
'99 Honda Passport
ByByeAmericanPie is offline   Reply With Quote
Old 09-02-2009, 11:33 AM   #3 (permalink)
lockmanmd's Avatar
Thanks for the suggestion. I have to see how hard it is to remove the vent. Don't want to break anything.
Old 09-02-2009, 12:42 PM   #4 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Don't know how close it is to the C-class as they share many parts.
Look at page 5 in the WIS document below and see if it's the same or similar enough to figure it out.
http://www.buellwinkle.com/COMAND%20...oval%20WIS.pdf
Old 12-26-2009, 07:31 PM   #5 (permalink)
MiamiMerc's Avatar
Date registered: Jun 2006
I have an 03 CLK 500 coupe that is doing the same thing and also the button that adjusts air mix and the two buttons that adjust the airflow on either side of the AC controls are so sticky its like they are melting. I have also seen this happen on C320 but I don't know what the cause or solution is.
MiamiMerc is offline   Reply With Quote
Metal/Hissing Noise, No Air From Center Vent christoj879 W126 S,SE,SEC,SEL,SD,SDL Class 4 05-02-2008 09:07 PM
How to remove center air vent? gixxerblack W220 S-Class 3 03-02-2008 02:15 PM
Center counsole vent only blows cold air 1derfoot W126 S,SE,SEC,SEL,SD,SDL Class 7 12-21-2007 10:22 PM
AC: center vent has no air? DinoMobile W126 S,SE,SEC,SEL,SD,SDL Class 2 09-09-2006 06:03 PM
Air conditioner vent repair, center Tom Sullivan W123 E,CE,D,CD,TD,TE Class 0 10-01-2002 08:43 AM
