Vehicle: 1993 190e-2.3; 1992 300E-3.0, 1998 Saab 9000T
You have beautiful metallic paint. About the most difficult to fix. I would first try Meguires StratchX. I have seen it do some amazing things on scratches and scrapes. Of course, it won't put paint back there it is missing, but it may make it look less noticable. If there is paint missing, a body shop is about your only good option.
The paint is completely gone there from the looks of it in the picture. Luckily for you its in a place that is not very noticeable and its near a seam so I would use touch up paint. It will not be perfect because its metallic but its a heck of a lot cheaper than your other options. Also because of where it is if you do a half descent job with the touch up only you will notice it. If this was the middle of a door or center of the hood then a body shop would be your only hope.
Just my opinion
Vehicle: 90 300SE (84k Miles) 08 Lexus ES350 Ultra (5k Miles) 07 GMC Sierra SLE (6k Miles) Sold list -->
It looks like some idiot drove up against you. Scratch-x will do nothing for you in this case. The clear coat and top coat are gone. You could try touch up paint, but it will be noticeable. The only real solution is to have that body panel resprayed by a good paint shop.
I believe you do not have to go to a paint shop. You can use touch up paint. Do it in layers, until you build up sufficient thickness of paint. Then sand smooth with 2000 grit paper. Once smooth, use a polish with a machine buffer to complete the process. If someone did not know you had fixed it, they would not be able to tell you where it was done.
"The true delight is in the finding out, rather than in the knowing." - Isaac Asimov
'99 SLK230 Sport
'00 ML320
'95 BMW 525iA (RIP)
'99 Honda Passport
Vehicle: 1999 SLK 230 - Firemist Metallic (548) 1983 300D TurboDiesel - Deep Blue (900)
That can look fine touched up. I believe you can get it pretty good. The base coat touched up and then very thinned out clear coat over that. Clean the area good with Lacquer thinner before you start. And get a small bottle of Clear coat and thin that just a tiny bit if need be with the Lacquer thinner so it will flow smoothly over to the edges of the missing clear after the base coat has dried. If it is just the right thickness it will fill it perfectly. Can take some experimenting to get the clear to the right consistency so don't be afraid to wipe it all back off with the lacquer thinner and try again.
