» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
Old 03-18-2008, 12:20 PM   #1 (permalink)
Date registered: Dec 2007
Vehicle: 1995 w140 S500
Removing Headlamps "Yellowing"
Does anyone recommend tips/products on how to get rid of the yellowing on the headlamps? Its not so much a "yellow color" (slight traces of the yellow color but blurry overall nonetheless)
I saw a product on pep boys today from blue magic thats supposed to remove yellowing after a couple sessions but I was skeptical so I chose to ask here first
Fu3lFr3nzy is offline   Reply With Quote
Old 03-18-2008, 12:33 PM   #2 (permalink)
Supporting Vendor
Justin@Adams's Avatar
Date registered: Feb 2008
Hey Fu3lFr3nzy,
If you have a Clay Bar I would try that first, with a Polish and Wax following!
Can you post some Pictures?
Thanks,
Justin Politte
Detail Tech
justin@adamspolishes.com
www.adamspolishes.com
Discount Code "SLMO"
Justin@Adams is offline   Reply With Quote
Old 03-18-2008, 03:08 PM   #3 (permalink)
roncor's Avatar
Date registered: Jan 2005
Vehicle: '87 560SL '93 190E 2.6 Sportline '80 240D
Here's a variety of specialized products designed just for headlights. I'm sure most of them would work for what you need. Check them out here:
Headlight Lens Care: Polish out scratches & haze to restore clear plastic headlight lens covers. Wolfgang, Meguiars, Plexus, lens cleaning system,
And, a guide "how to" do it yourself:Wolfgang Headlight Lens/ Clear Plastic Restoration Guide
roncor is online now   Reply With Quote
Old 03-18-2008, 04:07 PM   #4 (permalink)
Ballinger's Avatar
I just did the yellowed headlights of our Ford yesterday, using 400 grit sandpaper to wet sand, then 1000-grit scotchbrite to wetsand, then polishing compound, then Turtle Wax scratch-removing wax, all buffed with a drill-end buffer ball made of foam.
All the yellow came off and the lenses are much clearer. They are not, crystal clear as shown in the links above, however. Our were yellowish and rough even after washing. They're now clear, but still a little foggy, and smooth. My whole job took about 30 minutes to do both lights.
Ballinger is offline   Reply With Quote
Old 03-19-2008, 06:17 AM   #5 (permalink)
BenzWorld Detailing and Car Care Host
ByByeAmericanPie's Avatar
Date registered: Feb 2004
Vehicle: 1999 SLK230 Sport
I just did my girlfriend's daughter's lights. I started with 1000 grit wet sanding, followed by 1500 then 2000 grit. Then I finished off with plastic polish and a buffer. They looked brand new when I was done.
"The true delight is in the finding out, rather than in the knowing." - Isaac Asimov
'99 SLK230 Sport
'00 ML320
'95 BMW 525iA (RIP)
'99 Honda Passport
ByByeAmericanPie is offline   Reply With Quote
Old 03-19-2008, 09:43 AM   #6 (permalink)
Ryanoscerous's Avatar
Vehicle: 2001 E430 4matic
Me too...
same as BBAP except I bought a Mother's Poweball...amazing results!
Everything should be made as simple as possible, but not one bit simpler.
Albert Einstein
Ryanoscerous is offline   Reply With Quote
Old 05-09-2008, 08:18 AM   #7 (permalink)
Sorry for the long response. heres the link to my photo album that has the pics
As you can see, there seems to be some calcium deposits or yellowing(its actually more yellow in person), the camera unfortunately didnt capture it
Also I have glass headlights and from what i've gathered its a different method to clean them from plastic headlenses.
Someone said I cant use wet sandpaper because the friction will cause it to crack or something (lol?) or some other reasons but basically they said wetsand is a no-no.
So I am here to ask, is it ok to wetsand/polish the glass headlamps or should I try a different method?
Thanks in advance
Black on Black | 122xxx miles | "Xenon" Headlamps | '99 Tail Lights | S600 Grille | Clear Corners
Old 05-09-2008, 09:46 AM   #8 (permalink)
Do NOT sand glass headlamps. You can use polishes specifically made for glass like cereum oxide and a electric polisher. This should be all you need to get your glass lamps back to perfect.
Old 05-21-2008, 11:42 AM   #9 (permalink)
Thank for the tip. By any chance would I be able to pick up cerium oxcide at local stores? im not sure whether to look at an auto parts or hardware store (maybe theres another place?)
So once I get the stuff, any tips on how to apply it?
Old 05-21-2008, 12:33 PM   #10 (permalink)
KADE's Avatar
Date registered: Jan 2006
Vehicle: E-320/ 2000
HERE ARE 2 LINKS
Eastwood Company: Search Results for cerium oxide
CERIUM OXIDE GLASS POLISHING POWDER - JCWhitney Auto Parts
KADE is offline   Reply With Quote
"Yakuza" Sato's AMG Mercedes from "Black Rain" (starring Michael Douglas&Andy Garcia) JJB236 W124 E,CE,D,TD Class 20 08-06-2007 08:12 AM
RNC Chairman Mehlman next to get the boot, "resigns" (aka "gets fired too") FeelTheLove Off-Topic 0 11-09-2006 09:10 PM
500 SEC "brake bushings" & "castor supports" Graham W126 S,SE,SEC,SEL,SD,SDL Class 5 08-26-2003 12:14 PM
DREW - - On some posts your system puts a " " (space) in Message to kill the "NT" Jüri. W163 M-Class 3 08-07-2002 05:28 AM
