» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
Old 08-24-2007, 06:28 AM   #1 (permalink)
Date registered: Jun 2006
Vehicle: 2000 ml430
Gum on leather
My kids got chewing gum on the gray leather of my car seats.
Any tips on removing this stuff. I tried leather cleaning wipes that do nothing.
Thanks for any help
2000 ML430 744 Brilliant Silver
wbrokow1 is offline   Reply With Quote
Old 08-24-2007, 07:48 AM   #2 (permalink)
KADE's Avatar
Date registered: Jan 2006
Vehicle: E-320/ 2000
If gum is still soft, try a regular brown paper bag.....not the thick kind you put your groceries in, but the smaller brown paper bags you put small things in.
I've done it on fabric/clothing it works well, but never on leather. But I would imagine it would still work;
Depending on how much gum.....It could be a bit time consuming but it works!
Is you leather perferated where the gum is?
Also peanut butter works well believe it or not, but if your seats are perferated that WOULDN'T be the way to go! Also WD-40, and Goo be Gone (I have never used Goo be Gone) But people say its good for guey stuff
I would start with the paper bag first, because you will not be putting any chemicals on your leather. You may have to warm the gum up first with hair dryer or when car is hot from standing in the sun......so it will stick to the paper bag better.
so the list is:
Brown paper bag.
Peanut butter
WD-40
Goo Be Gone
Hope this helps.
KADE is offline   Reply With Quote
Old 08-24-2007, 08:31 AM   #3 (permalink)
benz rider's Avatar
Vehicle: 97'C280
I would suggest this method:
1. hot water towel, get as much as you can peel off first.
2. hot semi-soapy towel(hand soap or ajax liquid), to help break down the proteins in the gum. no need to soak the towel.
3. repeat step one until the gum is completely off.
don't wait til the gum is black, it'll be too hard to get off
good luck.
97' C280:
CLK wheels
H&R sport springs
Khumo's(new)
Tint
new Snowball machine
benz rider is offline   Reply With Quote
Old 08-24-2007, 12:32 PM   #4 (permalink)
~BANNED~
Date registered: Jul 2007
Thanks for any help
Whatever you try, try it on an inconspicuos area first. Cows aren't gray , which means you could remove color if you use the wrong solution, especially one with solvents in it.
Ice can harden gum to the point where it can be scraped or chipped off, but I've never used that method on leather. If you decode to go that route, put some ice in a thin plastic bag so you can get the gum cold but not get the seat wet.
PolishAndWax.com is offline   Reply With Quote
Old 08-24-2007, 01:04 PM   #5 (permalink)
BenzWorld Detailing and Car Care Host
ByByeAmericanPie's Avatar
Date registered: Feb 2004
Vehicle: 1999 SLK230 Sport
This always works with gum....
Use an ice cube to get the gum very cold...dry ice is even better (dont burn your hands). When the gum freezes it chips right off.
"The true delight is in the finding out, rather than in the knowing." - Isaac Asimov
'99 SLK230 Sport
'00 ML320
'95 BMW 525iA (RIP)
'99 Honda Passport
ByByeAmericanPie is offline   Reply With Quote
Old 08-24-2007, 03:53 PM   #6 (permalink)
Vehicle: 2000 ml430
ok thanks for the suggestions. I'll give them a try this weekend.
Yes the gum is on the perforations
Old 08-28-2007, 10:18 AM   #7 (permalink)
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: Mercedes-Benz
Send a message via AIM to Mercedes Benz of Florida Send a message via Yahoo to Mercedes Benz of Florida
Thanks for any help
Try a very cold Ice Cube! Once it freezes up the gum; you can pluck it off.
WD-40 also works like a charm, however, you MUST test it in an inconspicuous spot first, to make sure it does not further harm your Leather.
Lastly; Goof Off! also works.
Also test in inconspicuous area first. After all done and said; re-treat Leather with
Lexol or Leather Conditioner. Good Luck.
Charles
Orlando, Florida
United States of America
Mercedes Benz of Florida is offline   Reply With Quote
Old 08-28-2007, 07:11 PM   #8 (permalink)
Date registered: Jun 2007
Vehicle: 2003 SL500
You might try freezing the gum with
freezing wart remover (not the liquid stuff.....). It will break off. I've removed it from rugs (and hair) this way. You can be very precise in what you freeze with this stuff.
1309w is offline   Reply With Quote
Old 09-04-2007, 11:35 AM   #9 (permalink)
KADE's Avatar
Any updates?????? Did you get the gum out?????
Old 09-04-2007, 12:39 PM   #10 (permalink)
Formoque's Avatar
Date registered: Dec 2004
Vehicle: CLK 430 AMG
a piece of ice should do the trick!!
"I hear the colonal has grizzards"
Formoque is offline   Reply With Quote
W116 in Orbit chewing gum commercial H-TownBenzoboy W116 S, SE, SEL, SD Class 1 03-26-2007 08:53 PM
I hate gum... Andrew2004az Off-Topic 27 03-05-2006 07:20 PM
Nicotine Polacrilex Gum, 4mg barberhauler Off-Topic 3 09-27-2005 05:25 AM
Gum anyone..... C-Rod W163 M-Class 4 08-07-2003 08:21 PM
Gum on the Hood! fuzzybenz W163 M-Class 5 08-02-2003 01:49 AM
