» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
Old 08-13-2007, 08:51 PM   #11 (permalink)
~BANNED~
Date registered: Jul 2007
Originally Posted by slybydesignw210
Further more wet sanding will take off sections of clear coat and if you dont have the meter reader to view the depth of clear coat by section dont get it done.
What do you mean by 'sections of clear coat'? What meter reads 'depth of clear coat by section'?
Mil gauges (at least the ones I'm familair with) measure TOTAL paint on the car. That includes primer, base coat, sealer and clear coat. There is no mil gauge that I know of that can distinguish these three or four components of your total paint and certainly there are none that can tell you how many layers or coats of clear you have.
If I am wrong, please let me know the model and make of the mil gauge that does...I want one!
Also, nobody, no matter how skilled, should be wetsanding to remove swirl marks that are only viewable in the sun. That is extreme overkill.
PolishAndWax.com is offline   Reply With Quote
Old 08-13-2007, 09:47 PM   #12 (permalink)
slybydesignw210's Avatar
Date registered: Jan 2007
Vehicle: Opal Black 1998 MB E320 - Signs of Life- Pearl White 1994 Q45T
Thanks for correcting me. Its a mil gauge as you mentioned. Ive seened it used. when I said sections of clear coat, i was referring to the sections which has thicker clear coat then other like curved areas. When I wet sanding my car, I did a bit of research at some body shops and they all told me what sections to watch out for and never let the sand paper touch at all. I had alot of fun doing it and my car looks 200xs better. but i still dont recommend if some one is not prepared to get a paint job if they screw up.
It is What Its Creator Makes It To Be, I am SlyByDesign
slybydesignw210 is offline   Reply With Quote
Old 08-13-2007, 09:54 PM   #13 (permalink)
Old 08-14-2007, 08:09 AM   #14 (permalink)
~BANNED~
Ahhh...OK. Now it makes sense.
Using a mil gauge, find the areas that are 'lean' on paint and either stay away from them, or do them very lightly.
Gotcha.
Old 08-14-2007, 11:18 AM   #15 (permalink)
Date registered: Apr 2003
Vehicle: 2004 E-500
Thanks to you all for your great feedback. Before I could tell the detailer that I'm going to take my car back, he called me and said he polished and glazed my car again and it looks fine. We'll see when I pick it up. If it is still not in good order, I'll just find another guy. That said, one last quick quesiton...how many times can one polish a car without starting to really thin out a clear coat?
Thanks!
SLK99 is offline   Reply With Quote
Old 08-14-2007, 11:39 AM   #16 (permalink)
roncor's Avatar
Date registered: Jan 2005
Vehicle: '87 560SL '93 190E 2.6 Sportline '80 240D
Thanks!
Here's the deal on black paint and swirl marks....Polishing is good and removes fine scratches and swirls. Depending on the grit of the polish, you should be able to do this 2 or 3 times a year. A glaze is a temporary filler that shines for a short time - until you wash the car again! In my opinion this is a lazy and cheap way to obtain a 'short term' shine. The key is to remove the swirls with polish, then use a quality wax that will last for more than one hand wash! A variety of quality products are out there. But, you must either use a wax or sealer after polish to make the shine last. Also, do not use Ajax to wash your car!
roncor is offline   Reply With Quote
Old 08-14-2007, 11:48 AM   #17 (permalink)
Date registered: Jan 2006
Vehicle: 00 SL500
Cant give you an answer on that one. It all depends how agressive they got the prior times it was detailed!!!! Polishing really dosent remove much clear, Wet-sanding on the other hand can remove ALL of the clear if not done correctly. IMHO, I would not wet-sand!!! I have always had great luck with Maguires swirl-remover applied by machine, stay away from the edges of panels and finish around the edges by hand. I follow it up with a couple coats of NXT spread really thin, I do the second coat to elimanate ANY chance of missed spots or uneven finish. Then I make sure that ALL of my detailing stuff stays clean and dust free!!
drags1998 is offline   Reply With Quote
Old 08-14-2007, 11:49 AM   #18 (permalink)
~BANNED~
Amen! You just saved me a bunch of typing.
Old 08-14-2007, 12:01 PM   #19 (permalink)
roncor's Avatar
By the way, P & W, your products look very interesting! I will definitely give them a try.
Old 08-14-2007, 12:04 PM   #20 (permalink)
~BANNED~
Right on. Put the hammer to them and report your results here.
30-day money back guarantee if you don't like them. See my website for details.
Which “hide” swirls better? Obsidian Black or Jet Black? MBS430 Detailing and Car Care 3 06-21-2007 07:39 AM
New E500 With Swirls and Surface Scratches Hawaiian Detailing and Car Care 8 01-25-2005 07:28 AM
Put V8 Badges on my E500 abbam W124 E,CE,D,TD Class 19 03-29-2004 04:18 PM
Has anyone put a black grille insert . . . Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 27 07-21-2002 10:48 PM
Ran across an article about swirls in paint. Guy has a black car and bike. Anybody agree with this? Jones R170 SLK Class 5 03-25-2001 04:47 PM
