» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
Old 09-12-2006, 09:58 AM   #1 (permalink)
sunstealth
sunstealth's Avatar
Date registered: Jul 2006
best prduct for single stage almadine rot paint ?
what is the best product to use for a single stage almadine rot metallic paint,i want it to be smooth as a glass and a wet shine (always been able to achieve these results on bc/cc paint but single stage is new to me!)
thanks for your help
(btw meguiars products would be prefered)
sunstealth is offline   Reply With Quote
Old 09-12-2006, 11:15 AM   #2 (permalink)
Buellwinkle
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
What condition is the paint? What color? What is "single stage almadine rot metallic"? What do you mean by product (polish, glaze, wax, wash)?
Old 09-12-2006, 06:53 PM   #3 (permalink)
sunstealth
sunstealth's Avatar
the paint is not even on the car yet so let say it will be brand new!
i want a polish after i wetsand the car than a glaze a wax and a sealant
single stage is the type of paint (no clear coat, pretty much an urethane)
almadine rot is the color
i dunno if meguiars 80 or 83 is suitable for that type of paint after beeing wetsanded!
Old 09-13-2006, 03:49 AM   #4 (permalink)
cagalbraith
cagalbraith's Avatar
Date registered: Aug 2003
Vehicle: 2005 E320 Sedan
"Rot" is red...
cagalbraith is offline   Reply With Quote
Old 09-13-2006, 06:43 AM   #5 (permalink)
Yal
Date registered: Sep 2004
Try one grand. Use their glaze and blitz wax.
Are you sure you don't want to pay a little extra up front and get a clearcoat paint job? Single stage is so old school, the life expectancy on a single stage paint job isn't as long because clear adds added uv protection, and you have to realise that some single stage colors fade quicker then others. Red fades. Don't go cheap on paint. Personally I would sell my rims for a decent paint job.
Yal is offline   Reply With Quote
Old 09-13-2006, 11:14 AM   #6 (permalink)
Buellwinkle
BenzWorld W203 Host
I wouldn't wax or glaze until the paint has cured for at least 30 days. It's OK to use polishes but be careful controlling heat on your buffer as the paint underneath hasn't cured yet. After wetsanding down to about 1,500 grit, I usually use a product like 3M Imperial Micro Finish, or Malco's polish on a rotary buffer with a polishing pad to get the sanding marks out. For Meg's equivalent, use their Mirror Glaze Heavy Cut Cleaner #4 or Medium Cut Cleaner #1 (start with #1 and if that doesn't cut it, try #4. #83 is made more for a DA buffer and find it poops on on my rotary but I think you need more cutting power than that for removing wet sanding marks. Once the wetsanding marks and any defects are gone, then hit it with #80 with a DA buffer (or rotary) to get a finer shine and remove any buffing marks left from the stronger products. The car will look great at that point and you should leave it at that until the paint is fully cured. Then if you want that deep wet look, put on Meg's #3 machine glaze by rotary buffer or #7 Show Car Glaze by hand or DA buffer. Then wax over it, probably either their NXT Tech Wax (paste/liquid, doesn't matter but liquid is easier to use with a buffer) or their Hi-Tech #26 (sort of their replacement for #16 which can never really be replaced).
If that doesn't do it, I move up to a courser product, and I've used wool pads before to remove the sanding marks.
Old 09-13-2006, 12:57 PM   #7 (permalink)
sunstealth
sunstealth's Avatar
i wont clear the car cause im shooting it myself and i dont want to have the clear running, thats the only reason!
Why do rocker panels rot? AlanS W124 E,CE,D,TD Class 1 02-29-2004 07:14 PM
HID Stage I & Stage II Group Buy! 2nd2n01 W208 CLK Class 0 12-18-2001 01:40 PM
HID Stage I & Stage II Group Buy! 2nd2n01 R170 SLK Class 0 12-18-2001 01:40 PM
HID Stage I & Stage II Group Buy! Guest (MBNZ) W210 E50 AMG, E55 AMG 0 12-18-2001 01:39 PM
Arnee, which H&R's does Danz have on his car? Stage 2 or Stage 3.5 Cup Kit??? rage2 R170 SLK Class 5 03-12-2001 06:12 PM
