» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
Old 06-29-2006, 01:27 PM   #1 (permalink)
sstomcat's Avatar
Date registered: Jun 2006
Vehicle: ML-55 - 2000,
Looking for a Buffer/Polisher
I'm looking to buy a orbital polisher/buffer....there is lot of mention about Porter Cable 7336 DA buffer/sander at Lowes for $99...how does this compare with the Meguairs G100A...any recommendations for which one I should go for...
if there are others out there please let me know..
thanks in advance..
sstomcat is offline   Reply With Quote
Old 06-29-2006, 04:49 PM   #2 (permalink)
Date registered: Jan 2006
Vehicle: 00 SL500
The P-C seems to be VERY POPULAR, As a matter of fact, Its what I use, Someone said a while ago that the one from Lowes DOESNOT come with a very good pad!!!! JUST remember the pad is the MOST important part of this deal. you can always up-grade the pad later. These are VERY to use and its ALMOST IMPOSSIBLE to hurt the paint!!!!!!!!!! Start with the ajustable speed control at about 4 1/2 and POLISH to your hearts content Have fun!!!!!!!!
drags1998 is offline   Reply With Quote
Old 06-29-2006, 07:29 PM   #3 (permalink)
sstomcat's Avatar
I checked out the 7336 and man they are heavy!! anyone knows how is Meguairs G100A?
Old 06-30-2006, 04:05 AM   #4 (permalink)
BenzWorld Detailing and Car Care Host
ByByeAmericanPie's Avatar
Date registered: Feb 2004
Vehicle: 1999 SLK230 Sport
Looking at the G100A it appears that it was manufactured by Porter Cable and then a Meguiars label put on it.
"The true delight is in the finding out, rather than in the knowing." - Isaac Asimov
'99 SLK230 Sport
'00 ML320
'95 BMW 525iA (RIP)
'99 Honda Passport
ByByeAmericanPie is offline   Reply With Quote
Old 06-30-2006, 08:04 AM   #5 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Porter Cable makes 2 very similar buffers, the only difference is the counter weight inside and it wouldn't really make any difference in how it works, the 7336 and 7224. The G100 from Meguiars is a 7224. If for some reason the psycological effects of not having the exact same counter weight bothers you, you can get replacement counter weights for a few dollars. The advantage of the G100 if you can get it at a good price is that Megiars warranties it for life, comes with a proper backing plate and 1 pad.
Old 06-30-2006, 08:46 AM   #6 (permalink)
sstomcat's Avatar
Thank you for the feedback...I can find a G100A for $149 ...do you think this is a good price...also do not know the difference of between G100 and G100A?
Old 07-01-2006, 06:26 AM   #7 (permalink)
SunGuy61's Avatar
Vehicle: 1987 560SL For Sale & 1999 SL500 For Keeps
Send a message via AIM to SunGuy61
I found this site in my search for a buffer/polisher. They provide a Porter Cable 'Kit' that comes all inclusive including pands, backing, even sand paper for $189....seems pretty reasonable to me for all you get. FYI
http://www.topoftheline.com/index.html
Bob
SunGuy61 is offline   Reply With Quote
Old 07-01-2006, 10:16 PM   #8 (permalink)
BenzWorld W203 Host
The Porter Cable kit you described is exactly what you get from Lowes for $99 (sometimes cheaper on sale). The pad and sanding paper are no good, throw aways, dissintegrates while you use it. $149 is a great price for the G100a because you get the $99.99 buffer plus about $25 for the Megs backing plate and pad so for the $25 difference you get great support from Meguiars and a lifetime warranty (vs. 1 yr with PC). I would do that. The reason I went the other route is at the time Meguiars wanted over $200.
Old 07-03-2006, 06:30 AM   #9 (permalink)
SunGuy61's Avatar
Hey Buellwinkle,
Thanks for clarifying what's in these 'kits', I'm off to Lowes!
Bob
Old 07-03-2006, 04:28 PM   #10 (permalink)
Date registered: Feb 2005
SunGuy61,
The website you mention is great. I would recommend the Cyclo Polisher. It is awesome. It will not disappoint you. Whatever it costs now, it is worth. I have been using my Cyclo for about 4 years and it makes polishing/waxing addicting. It is very easy to use. It is expensive but worth it.
DiceCedes is offline   Reply With Quote
