» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
Old 06-20-2006, 03:21 PM   #1 (permalink)
Date registered: Mar 2006
Send a message via ICQ to wuzoo Send a message via AIM to wuzoo Send a message via MSN to wuzoo Send a message via Yahoo to wuzoo
tips and tricks
Hi
what are your tips and tricks to give your car that added sparkle?
mine is to use neat zymol car shampoo, as opposed to adding half a cap to a bucket of water. For me, pouring neat zymol on a sponge and washing, makes the car super radiant.
EdiT:If you try this, then test on a small area before doing your car!
wuzoo is offline   Reply With Quote
Old 06-29-2006, 06:41 AM   #2 (permalink)
Date registered: Aug 2005
Vehicle: 1993 W201 190E 1.8i
lemme guess.
you work for Zymol.
this is your 'employee idea of the month' to get folks to use waaaay more Zymol.
of your car shampoo isn't doing its job, don't resort to using it neat.
ditch it and spend a little more money on something better.
'93 W201 Euro 1.8568 Signalrot • 16x8J Evolutions
W201 ROTM February 2007
190Evoluzione is offline   Reply With Quote
Old 06-29-2006, 07:39 AM   #3 (permalink)
Yal
Date registered: Sep 2004
Originally Posted by 190Evoluzione
lemme guess.
you work for Zymol.
LOL
Yal is offline   Reply With Quote
Old 06-30-2006, 05:09 AM   #4 (permalink)
BenzWorld Detailing and Car Care Host
ByByeAmericanPie's Avatar
Date registered: Feb 2004
Vehicle: 1999 SLK230 Sport
Using shampoo neat on a sponge is not recommended. You will not get sufficient lubricity to lift and wash away fine grit. The mixture of water and shampoo gives the best results in lifting away grime. If the shampoo you use does not preform when mixed with water, it is probably not worth the money you spent on it.
"The true delight is in the finding out, rather than in the knowing." - Isaac Asimov
'99 SLK230 Sport
'00 ML320
'95 BMW 525iA (RIP)
'99 Honda Passport
ByByeAmericanPie is offline   Reply With Quote
Old 06-30-2006, 09:13 AM   #5 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
It just goes with the philosophy that if what the manufacturer's recomended dilution is good, then a lot more is a lot better. Just funny to hear but AmericanPie is right, the chemist designed a product to be diluted a certain way, using it in full concentration is not going to make it better or your life easier. It's like people that fill their radiators with 100% radiator fluid and then overheat or the people that cake the wax on thinking that a good thick coat of wax will make it shinier until they try and remove it.
