» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Detailing and Car Care
Old 10-23-2004, 07:43 PM   #1 (permalink)
Date registered: Sep 2004
Vehicle: 97 E320
Klasse Wax
This is the first time iam using this wax and if anyone out there has used it I have a few ?'s
With the kit you get 2 sponge applicators what are they used for, it seems that both the all in one polish and the glaze are put on with the teri cloth appl.
The instructions say that you only need to use about 1-2 ounces of the glaze on a wet teri is this really true? If so that means since the bottle has 38 ounces and you only need use this once a year then this would last for about 19 yrs nice!
It also says to put this on thin what would be thin like you can just see it go on?
Do you have to repeat the glaze everytime you use the all in one or it doesnt effect it?
thanks
Wizard2 is offline   Reply With Quote
Old 10-25-2004, 08:24 AM   #2 (permalink)
Date registered: Mar 2004
RE: Klasse Wax
Hello Wizard,
I am only a user of the AIO as it is a wonderful gloss enhancer.
The SG I am not a fan of as I prefer another sealant.
While the AIO is perhaps one of the best products to use in terms of gloss and wetness factor it does not do well in the durability stage. It should always be topped with a sealant and/or carnauba wax.
As for application, AIO goes on easily and if applied in a thin coat as per instructions it should also be easily removed. Many detailers apply it wet and remove it wet. In other words they wipe on and wipe off.
A bottle of the AIO should last you a long, long time if you have only one or two cars.
The AIO always needs to be sealed when re-applied as it will remove any wax previously applied. So if you have a sealed car that needs a bit of a touch up, say from a bird dropping, then after the cleaning and polishing with the AIO it should be sealed with either the SG or a wax.
Hope that helps,
Anthony
"The Art & Science Of Auto Detail"
Anthony Orosco is offline   Reply With Quote
