Hi guys,
Today I pulled down the front passenger window and it did make a lot of squeaky noise when doing so. I then got the window back up but when I tried to take the window down again nothing happens? The window motor only makes a grinding noise like the window jumped out of the motor mechanism as it does not follow the motor?
Or is the window regulator broken? If I push the window button the motor still runs but makes a terrible grinding noise and nothing happens with the window.
Is it worth to take off the door panel and check if I can put the window back in "place" so the motor will run the window?
thanks for your help :smile
