I don't quite understand the question, but I think you want to be able to push a specific number and your seat position, steering wheel and mirrors adjust? You have to get all in position the way you want them, then push the "M" and the 1 simultaneously..then to test it, move your seat or steering wheel then just push the 1 and it should go into the set position.....then repeat for #2 and 3...I have a just relaxing position (ok, showing off) and then comfort (long drives) position since I am the only driver....Hope this helps.
actually, I was under the impression that you could sync the memory programmed on the car seat to the key. So when you enter the car it automatically adjusts based on the key used to open it.
I have an Infiniti, and that’s how the feature works.....so I assumed it would be the same on the CLS.
I assume you mean the Easy-entry feature. When activated in the 06 CLS only the steering wheel moves. As a matter of reference, the seat moved in 03 – 05 E-Class vehicles however was discontinued for 06.
Key to position 1 – MFD – Settings – submenu Comfort – select Easy-entry – Easy-entry function on
I had two BMWs and they both had key specific memories. MB doesn't have that function across their product lines and I've had 3 Bimmers and 4 MBs. Hope this helps.
I think they do. If I recall well in the user's manual it is clearly explained how to synchronize each key to the seats. I would have to look into it but 90% sure it is possible.
