In this topic I will be posting my experiences as I install a Double Din head unit and a new sound system bypassing the fiber optic sound system in my 2001 CL55. The weight and look of the system will be as stock as possible because it's a racecar lol (to me this isn't the type of car you throw two 15" speakers in the trunk). I am posting this topic because there isn't really that much info anywhere on the web for the sound systems of the C215s. I have found some info on forums but not enough for someone who hasn't dealt with this type of car before or mite be a little scared to do so.
Skill Level: Some electrical experience, good aftermarket audio system install experience.
I will be replacing the factory fiber optic amp and all the speakers. 16 year old Bose just isn't doing it for me anymore. On the display between your speedometer and tachometer there will no longer be access or display to the audio, navigation, or phone.
This is for anyone who has never dealt with this type of system or is new to Mercedes. If you break parts on your car or the system doesn't work properly I will not be responsible. Also I do not work or advertise for any of the mentioned companies.
This information was gathered from the great members of BenzWorld, sources I've found from searching the internet, contacting audio companies, and what will be, my experiences.
First you will need a DASH KIT or radio bezel that fits the double din you would like to use. You can make your own dash kit which many people have or: From what I have found for an ordinary sized double din you can use an aftermarket W220 double din dash kit/bezel with a little modification. You will still need to cut your center dash where the old head unit sat. There is a company that sells the kit for a 2001 C215 (over priced). But if u click on the individual parts you will see the kit uses a bezel from a W220.
Link: http://shop.mediaexponent.com/Tarjous-nro-1101
I bought mine on Amazon for about $60 in wood grain.
Second you will need a WIRING HARNESS.
I could not find a wiring harness that fit by searching by my car so I contacted the sales team at Metra Audio. The salesman I spoke with said the Part number: 70-9401 would fit if you are bypassing the fiber optic system. Which means new amps.
Third you will need a steering wheel control interface if you would like to keep the steering wheel controls. Axxess Interfaces makes a steering wheel control interface that will connect to Mercedes with a couple wire connections.
The Speaker sizes in the doors are 6.5". I'm not sure the size of the center speaker in the dash yet but I will update when I find out. There is a subwoofer in the rear deck it is either a 8" or a 10" but I am custom fitting a 10". So buy speaker of your choice accordingly.
I will post pictures and updates as I go along with the install.
I have not began the install yet so input is welcome. Thank you to all the members that have shared info with me on this subject.
