The purpose of this thread is to collect and organize the best ABC-related intelligence—as well as general-interest and DIY material—thus far shared in this forum. Any and all interested parties are invited to make contributions, criticisms, and references wherever indicated.
This post (scroll down) now serves as a general-issues sticky for non-ABC matters. (See the next post for ABC Threads.) Like it or not, our cars are aging, they are quite complex, and they'll have issues from time to time. We're here to help each other.
NB: Keep in mind that the W220 sedans are mechanically very similar, and vastly more numerous. Therefore the W220 Forum here at BenzWorld has a greater wealth of information, much of which applies to our cars. See especially their W220 Encyclopedia!
W215 Fuse & Relay Charts
http://www.benzworld.org/forums/w215-cl-class/1599665-w215-fuse-relay-chart.html
W215 hidden fuses revealed
http://www.benzworld.org/forums/w215-cl-class/1625470-w215-hidden-fuses-revealed.html
Car Won't Start? Some possible explanations
http://www.benzworld.org/forums/c21...wont-start-useful-information-pertaining.html
DIY remove/install starter for all W215 engines
http://www.benzworld.org/forums/c215-cl-class/2726345-diy-remove-install-starter-all-w215.html
Serpentine Belt + Tensioner (V12)
http://www.benzworld.org/forums/w215-cl-class/2363705-serpentine-belt-tensioner.html
Mercedes CL500 Wiring diagram
(Sorry, broken Link needs Update)
Aftermarket Stereo: Double DIN Install on 2001 & 2003 C215
http://www.benzworld.org/forums/c215-cl-class/2711409-double-din-install-2001-2003-c215.html
Power assist doors & trunk issues
http://www.benzworld.org/forums/w215-cl-class/1664704-power-assist-doors-trunk-question.html
Transmission Shifter Stuck in Park (From W220 Forum)
http://www.benzworld.org/forums/w220-s-class/1455706-shifter-stuck-park-handy-tools-heres.html
A/C Condensor Replacement
http://www.benzworld.org/forums/w21...l500-c-condenser-replacement.html#post9623009
CV Boot replacement with MB parts
http://www.benzworld.org/forums/w215-cl-class/2423273-cv-boot-replacement-mb-parts.html
Tire advice / consensus
http://www.benzworld.org/forums/w215-cl-class/1568989-best-tires.html
Ozan's Unofficial Mods & Maintenance Center
http://www.benzworld.org/forums/w215-cl-class/1691416-stickey-please-list-how-helpful-maintenance.html
Edmunds Mercedes-Benz CL65 Long-Term Road Test
http://www.edmunds.com/mercedes-benz/cl-class/2005/long-term-road-test/introduction.html
http://www.edmunds.com/mercedes-ben...mercedes-benz-cl65-amg-another-abc-fault.html
http://www.edmunds.com/mercedes-ben...-pad-abc-and-check-engine-warning-lights.html
BenzWorld Member-Recommended Independent Repair Shops
Before starting a new thread:
(Note that the Forum Search feature now permits Google Search as an integrated function, and it often works better than the 'VB Search' option.)
PS: And for God's sake, people, when someone goes out of his way to help you with a problem, have the decency to thank him and/or hit the 'Like' button. Way too many people vanish after their problem was solved without even saying thanks.
For the uninitiated, the ABC (Active Body Control) system is Mercedes's electro-hydraulic suspension which constantly self-monitors and adjusts suspension settings thereby virtually eliminating body roll and pitch in various driving situations including cornering, accelerating, and braking. You'll find it on CL and SL models; however I note that it's been supplanted by Airmatic in most W216 CLs.Free Advice said:
We are linking some of the clearest and most-informative ABC threads in the next post in this thread. Please contribute your own--just link here to the posts if they're already on the forum, and I'll take care of the cleanup. No way can I do this alone.MBUSA.COM said:
