2004 clk320. Passenger headlight is out. This is the main light for driving. I replaced with a new H7 and still doesn't work. I swapped the working drivers side one to it and it still doesn't work? Drivers side light and all other lights work? I don't see corrosion or anything like that? Car is well maintained. Is there a fuse? Location? Any ideas?
Thanks for replies. There are stock not xenon. The h7 works on the driver side. Nothing looks to be disconnected. Wires appear to be in good shape? What is SAM?
This post shows the confusion caused by not specifying exactly what features you have on your car and as rudeney states, you probably do not have Bi-xenons.
Can you follow a circuit diagram? This WIS diagram below is one of 6 diagrams that cover the operation of Front SAM N10/1, which drives the front lights.
Page 1 covers the arrangement for halogen lights. Bi-xenon lights are on page 2 inside dotted box referenced U501, so ignore that area.
E2e1 is your rght side high beam. You can check-out the loom with a testmeter set to the ohms range.,The path apparently not working is:
from N10/1 connector 5 pin 5 - to lamp E2 socket 3.
However I doubt that the loom is damaged, or that the SAM is faulty, and I would concentrate on the lamp socket for minor corrosion.
