clk350 inner key - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 11-20-2012, 09:31 AM Thread Starter
Date registered: Oct 2012
Vehicle: 2007 CLK350
Post clk350 inner key
Gmorning all. I recently purchased a 2007 clk350
Just wondering what this inner key is for (see attached photo). The seller told me it was to lock the glove box, but i dont see a keyhole on the glovebox for it.
please advise. Thanks
MsLuscious is offline
post #2 of 11 (permalink) Old 11-20-2012, 10:24 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 405 Post(s)
It's an emergency key to unlock the driver's door if the battery in the fob is low and the central locking fails. It fits inside the remote key.
You can start/drive the car without a good battery in the fob.
keyhole is offline
post #3 of 11 (permalink) Old 11-20-2012, 10:40 AM Thread Starter
that makes sense! so its not for the glove box, or the trunk?
also, how would it be used to start the car?
post #4 of 11 (permalink) Old 11-20-2012, 12:42 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 650 Post(s)
The glove compartment in the W209 has no lock (except for the cabriolet, and then the lock is electric and tied into the door locks). Earlier models of the W209 CLK did have a lock on the center armrest cover that used the key, and other MBZ models do have locking glove compartments using the key.
As Keyhole said, that key is only to be used in a situation where the vehicle battery or the SmartKey fob battery is dead so the Remote Control Locking (RCL) function doesn't work. You should have a key slot in the driver's door handle as well as on the trunk (next to the handle, above the tag). By the way, to open the trunk with the hard key, you insert the key and turn it, then pull the handle.
The battery in the SmartKey fob is only used for RCL. To start the engine, the ignition switch has and inductive coil that powers the circuitry in the SmartKey so it can validate it.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is offline
post #5 of 11 (permalink) Old 11-21-2012, 04:11 AM
keyhole's Avatar
Quoted: 405 Post(s)
This page from the WIS explains how to use the remote key on your W209. Note the 'Global' and 'Selective' modes available.
keyhole is offline
post #6 of 11 (permalink) Old 11-21-2012, 08:27 AM
rudeney's Avatar
Quoted: 650 Post(s)
One other item on the trunk...to open it with the hard key, inset it into the lock and rotate it 90-degrees counter-clockwise, then pull the handle. For cars before MY2005 (and some late MY2004s), you can also rotate the key 90-degrees clockwise, then remove it and this will "valet lock" the trunk -it cannot be opened with the SmartKey RCL function or with the release button in the cabin.
EDIT: I checked this on my 2007 CLK and it has the valet lock function. According to dealer documentation, it was deleted with MY2005, but maybe it was added back later. Or, maybe it's still there on the cabriolet. Anyhow, that's another feature of the hardkey if the vehicle is equipped that way.
- RODNEY
rudeney is offline
post #7 of 11 (permalink) Old 11-26-2012, 11:27 PM
Date registered: Nov 2012
key is just to be utilized within a scenario where the vehicle electric storage device or the smartkey fob electric cell is dead so the remote control locking method doesn't work. You may as well have a nexus opening in the driver's entryway handle and in addition on the trunk.
Zingerdam is offline
post #8 of 11 (permalink) Old 11-27-2012, 07:05 AM
Vehicle: 2007 Mercedes CLK 350, 2001 Mercedes e320 4matic
One time I opened the door with the inside key and the alarm went off. Is this normal? Why would it do this?
Sent from my iPhone using AutoGuide.com Free App
Benz441 is offline
post #9 of 11 (permalink) Old 11-27-2012, 07:21 AM
rudeney's Avatar
Quoted: 650 Post(s)
Yes, opening the door with the hard key will trigger the alarm. Basically, when you set the alarm via the fob's RCL function, it will be triggered when any door, trunk or hood is opened unless you unlock via the fob (thus disabling the alarm). The same thing will happen if you sit in the car, lock the doors via RCL then open a door to exit.
- RODNEY
rudeney is offline
post #10 of 11 (permalink) Old 11-27-2012, 07:29 AM
Oh makes sense I guess. Our 2010 commander had a similar looking key fob. It would do the same thing. And the key fobs kept failing. We would get looks from people thinking we were breaking into it lol. Went thru 2 sets of keys and they still don't work intermittently. We have never had a problem with the Mercedes key
Benz441 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
