uh when it rains it pours......the computer bit in the centre dash, the one with all the mpg, outside temp etc etc is so dim i cant read it.....it occasionally goes bright and then goes all dim again.....could this be connected to the sensor panel behind the rear view mirror do you think???
I believe that is manually dimmed by twisting the trip odometer reset stalk. Try giving it a full left and right rotation to see if that helps. If not, then it's probably a loose connection or faulty electronics inside the cluster. Cluster repair is a big problem - you almost end up just having to go to the dealer for a new cluster, which is expensive - $2K+
