Keyless remote resync.... HELP!!! - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-27-2012, 02:46 AM Thread Starter
Date registered: Jan 2012
Question Keyless remote resync.... HELP!!!
Hey guys,
The other day, the message "check remote batteries" popped up on my dash. I replaced the batteries with no problem and the message went away. However, now it seems as if the RF function between the remote & the car has been lost. Only the Infared works. I can no longer stand several feet away and lock/unlock the car like I could before I replaced the batteries. I know the remote works because I can open the car by either pulling the handle or pressing the unlock button with the infared pointing at the handle.
Is there a way to reset/resync the RF between the remote & the vehicle? I do have keyless go. 2006 CLK coupe.
Thanks.
CLKguyATL is offline
post #2 of 5 (permalink) Old 01-27-2012, 09:51 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 531 Post(s)
Simultaneously press and hold the LOCK and UNLOCK buttons on the fob until tis LED light blinks twice. This toggles global vs driver-door only unlocking and can sometimes "wake up" the RCL function.
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is online now
post #3 of 5 (permalink) Old 01-27-2012, 10:42 PM Thread Starter
Yeah, tried that several times.... No luck.
post #4 of 5 (permalink) Old 01-28-2012, 06:15 PM
rudeney's Avatar
Quoted: 531 Post(s)
Have you started the car by inserting the key into the ignition or the KeylessGo START button? If not, try the ignition switch. There is some communication that occurs that way that does not via KeylessGo. Also, does the other key work?
- RODNEY
post #5 of 5 (permalink) Old 01-28-2012, 08:21 PM Thread Starter
The key functions fine in all other situations (ignition, keyless start, and infared). It just doesn't work when trying to lock/unlock vehicle from let's say 10 feet. Unfortunately I only have 1 key.
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
    keyless entry remote works once a day(not remote battery) burnettemark W163 M-Class 1 12-10-2008 04:08 PM
    Keyless Remote Help matman_forever W163 M-Class 1 11-30-2007 07:59 AM
    Keyless Remote - any one know this guy? smack W126 S,SE,SEC,SEL,SD,SDL Class 15 10-17-2007 07:16 PM
    Keyless Remote Freddylaw R170 SLK-Class 4 12-22-2005 12:16 PM
    Keyless Remote Neicey59 W163 M-Class 13 12-15-2001 05:01 PM
